turning boost up, will it be safe?
Old Jun 27, 2004 | 07:51 PM
JamesH's Avatar
JamesH
Default turning boost up, will it be safe?
its had a top end rebuild and bottom end is from the factory on 90k, currently running 18/20psi, and would it be safe to run 26psi? do you think?
the secs says max boost is 24 psi and it has a 2 stage boost switch, which doesnt seem to make a difference (according to the secs it does by about 1psi)
its running 3bar map sensor greens, rs500 intercooler ect.
how would it affect the secs by boosting more than 24?
what would happen to the 2stage boost switch?
thanks!
Old Jun 28, 2004 | 04:03 PM
JamesH's Avatar
JamesH
Old Jun 28, 2004 | 04:08 PM
Jim Galbally's Avatar
Jim Galbally
not worth the risk touching it imho
Old Jun 28, 2004 | 04:54 PM
Kev H's Avatar
Kev H
i thought that 24psi was on the limit for 803's?
Old Jun 28, 2004 | 05:09 PM
JamesH's Avatar
JamesH
i thought 28 was a resonable limit? and like 30.5 on greys?
Old Jun 28, 2004 | 08:38 PM
brad's Avatar
brad
go for it smids
take the amal off and put a bleed on it ,
its not like the car is used on track or pushed really hard all the time is it bud
im sure you should be able to hit at least 26 with greens
Old Jun 28, 2004 | 08:39 PM
stevo's Avatar
stevo
APMSL thats rich comming from Mr fiddler himself
Old Jun 28, 2004 | 08:41 PM
Billabong's Avatar
Billabong
There speaks the voice of experience
Old Jun 28, 2004 | 08:57 PM
lamb chops's Avatar
lamb chops
I wouldnt do it.. Not without getting it checked for detonation. Are you running a standard t3?
Old Jun 28, 2004 | 09:05 PM
POPEYE's Avatar
POPEYE
FAIRY CAKE
dont be a silly boy,
Old Jun 29, 2004 | 10:12 AM
JamesH's Avatar
JamesH
its running a hybrid T34
Old Jun 29, 2004 | 10:19 AM
GARETH T's Avatar
GARETH T
there is many reasons why you shouldnt try it
leave along
Old Jun 29, 2004 | 12:27 PM
JamesH's Avatar
JamesH
OK thanks
timsrs
Nov 13, 2018 11:48 AM
muzzman1
Sep 30, 2015 08:59 PM
rsguy
44
Sep 29, 2015 03:29 PM
Russ Payne
Sep 25, 2015 08:29 PM
