TORQUE SETTINGS
Old Aug 13, 2005 | 02:26 AM
STUCOS's Avatar
STUCOS
Default TORQUE SETTINGS
OK folks i know it,s in wrong forum,but most ppl dont look in technical,well im going to build my mates 4x4 cossie engine tomorrow ,but what i need to know is head bolt torque settings,he is useing arp studs and a metal head gasket
cheeRS stu
Old Aug 13, 2005 | 04:59 PM
STUCOS's Avatar
STUCOS
OK guess every body just tightens them down,and wishes for luck,buy the amount of replies any way
cheeRS stu
Old Aug 13, 2005 | 07:26 PM
Guinnless's Avatar
Guinnless
That's cos most people either use normal stretch bolts or long stud.
Th ARP studs don't allow for 'movement' caused by two different materials of differing thermal expansion rates.
The result tends to be a cracked block around where the studs fit into the block.
Old Aug 13, 2005 | 07:34 PM
SteveB's Avatar
SteveB
Std head torque is......
1. 45-50 nm
then
2. 180 degrees
But some of the ARP bolts (not sure on the Cossie) have a different torque setting so check this 1st...
steve.rst
Mar 15, 2016 08:01 AM
lime
Sep 25, 2015 06:56 PM
IainRS1700T
Sep 25, 2015 06:44 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
JamboRS
28
Sep 14, 2015 09:02 PM
