Anyone know much about multithrottle + turbo
Looks like i will be using ITBs on a blown motor im building.
Little worried about getting a reliable map reading as the way i see it, at part throttle on one cylinder it will see boost (valves closed) and on another it will see vacuum (asusming less air from boost past that part open throttle than the engine is consuming in vacuum on that cylinder)
So whats the best way to do it?
Im guessing on just using a balance pipe running beteen the 4 ITBs?
How do liners do it when they are getting a MAP reading?
No because the plenum (which yes you are right i have a single one) is BEFORE the throttle plates, which means the pressure in there isnt the same as the pressure in the manifold as you get a pressure difference after the butterfly when its only partially open, what you say would be fine on WOT though.
Chip,
In this scenario, ecu's use a combination of MAP and TPS to estimate the fuel
demand during throttle closed/vacuum conditions.
Generally TPS is used ONLY for load calculation at say below 10% TPS and between
10% and 25%, a combination of 50/50 is used.
Above 25% then only map is used.
These figures are estimates as it WILL vary depending on engine design.
lee, yeah i may be able to do it that way i guess, and just use a single throttle before the plenum, would have prefered this way though, if only cause ive got a spare set of bodies lieing around that fit perfectly!
SECS, hmm, not sure how i could set DTA up to do that, you have to either pick TPS vs RPM with MAP as just an adjustment or vice versa, you cant do half and half as far as i know.
Anyone else got any useful input?
will my theory with balancing MAP out using a balance bar not work for any reason, if so why?
Like has been said above...
Guesstimate (map/TPS).
Switch to a hotwire/hotfilm air mass meter.
Or run a vac plenum chamber.... inter connect all the TBs to a common closed chamber and take the map reading from there.
Alex
Alex
Chip use a balance pipe between the 4 TB's then a single pipe to a mapsensor,
This is how the GTR's work I have just mapped 1 with 1680cc Injectors with Autronic's Throttle/pressure mapping, Main fuel table TPS up to 100% then Boost pressure, Ignition table is map/pressure based,
I mapped this in 9 presses of the Accle to 2.2bar boost this system works floorless
Mark
Mark
Mark
Mark
god of mapping
leecavturbo, The GTR also has a small plenum also just to stop the pulsing but this doesnt stop the vastly diff flow when the throttle is opened and closed, the Ecu will need its own style comp table/mutli maps for this.
Thanks Mark
Thanks Mark
just noticed your location , i saw/heard you going up the A5 near brownhills @ about 6pm the other night ( donnington visiting ? ) looks/sounds good
Best it's ever been at the moment
Cheers for the comments
Mark
Mark
Originally Posted by stevieturbo
Another question. What are the expected gains over a good sized single throttle and decent inlet manifold/plenum ??
Is it enough to make it worth the hassle ?
Cam
Mark, thanks for that, much appreciated, looks like i was thinking along the right lines.
re: amm
I dont like airflow meters (or air mass), would prefer not to use one if i dont have to.
re: hassle
Its not any hassle ive got them sat here complete with a manifold and plenum all made up ready to bolt on, so providing i can get a half decent map sorted its not an issue.
cheers everyone for your input
re: amm
re: hassle
This was how I did it on my old mini.
Basically a small chamber where all 4 inlets go to.
vac signal was around -14hgmm to -15hgmm and the idle was a bit awkward to be keep balanced but I think that may have been more down to the throttle linkage. After that I made a single throttle plenum/inlet and vac was closer to -22hgmm and idle was much better to control.
Also I am pretty sure the gti-r has a chamber where all 4 vac pipes go to situated under the the manifold.
Regards muppet.
Regards muppet.
Mark
Mark
which is exactly what me and chip were saying 2 weeks ago
i guess he just wanted some different opions
Mark
JK12
33
Apr 26, 2021 12:09 PM
