ERST Does this fuel mod work
Old Aug 11, 2005 | 09:29 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default ERST Does this fuel mod work
http://cgi.ebay.co.uk/Escort-rs-turb...QQcmdZViewItem
just wondering
Old Aug 11, 2005 | 09:55 PM
haz87's Avatar
haz87
its just a fifth injector isnt it
Old Aug 11, 2005 | 09:59 PM
Eagle's Avatar
Eagle
Super Moderator
yes ... speak to mark shead but there is more to it than that i beleive
Old Aug 11, 2005 | 10:00 PM
Keith B's Avatar
Keith B
You'll only get the best from that mod if you raise the back of your bonnet up my 2ft and 5inches.
Old Aug 11, 2005 | 10:03 PM
Roosie's Avatar
Roosie
Old Aug 11, 2005 | 10:04 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Thats the legendary Fumes Mod.
Old Aug 11, 2005 | 10:06 PM
EIL132's Avatar
EIL132
Was about to say the exect same thing, apart from I'd change it to sniffer mod Performance Fords worst hour
Old Aug 11, 2005 | 10:08 PM
Rsmat's Avatar
Rsmat
another quality piece 4 sale on ebay
Old Aug 11, 2005 | 10:11 PM
Christian and Beccy
#1 in Spelling Club
That pipe would be better used to supply a Boost feed to the Amal Valve/Boost Controller/Bleed Valve instead of the one on the Compressor Scroll IMO.
Old Aug 11, 2005 | 10:18 PM
thats what Tom Scarlet done to my ERST only took about 5 mins to do as what Christian and Beccy said
Old Aug 11, 2005 | 10:26 PM
©hatter Box's Avatar
©hatter Box
not this old bean mark shead and ahmed use them both
Old Aug 11, 2005 | 10:48 PM
Keith B's Avatar
Keith B
Why not connect that boost pipe to some valves on the bonnet lifters so as the boost goes up so does the bonnet
Old Aug 12, 2005 | 03:06 PM
JamboRS's Avatar
JamboRS
focus rs 1672
is there not 2 ways of doing this mod
im sure you can join it to metering head for the fumes mod
but im sure AVA have got mine goin into amal valve,ill need to check later
Old Aug 12, 2005 | 03:10 PM
Jim Galbally's Avatar
Jim Galbally
its a crossover pipe with a pipe tapped into it... hardly special now is it
Old Aug 12, 2005 | 04:07 PM
Neil S's Avatar
Neil S
When Colin saw this on my old RST he said "Whats this? Do you WANT your car to blow up?"
Neil.
Old Aug 12, 2005 | 04:12 PM
ballin's Avatar
ballin
its not a 5th injector!?
always seems to be some controversy around this mod, cant really be arsed to give it a try tho
Old Aug 12, 2005 | 04:13 PM
JamboRS's Avatar
JamboRS
focus rs 1672
how times have changed then eh
a pic of my engine bay that all my work was done at ava
Old Aug 12, 2005 | 04:22 PM
Wazzzer's Avatar
Wazzzer
thats not the fuel mod, thats so you don't have a boost drop...
Old Aug 12, 2005 | 04:35 PM
Eagle's Avatar
Eagle
Super Moderator
you sure
Old Aug 12, 2005 | 04:39 PM
Wazzzer's Avatar
Wazzzer
now you mention it I'm not sure Eagle
Billabong's Avatar
Billabong
...and it works as INTENDED - just not many people realise WHAT the actual mod' is for......
Old Aug 12, 2005 | 04:46 PM
Wazzzer's Avatar
Wazzzer
so its not a fuel mod Bill?
Old Aug 12, 2005 | 04:52 PM
whats a fuel mod?
Old Aug 12, 2005 | 04:53 PM
EIL132's Avatar
EIL132
People are getting mixed up, the original "fume mod" that appeared in Performance Ford was where petrol fumes were re circulated into the crossover/inlet to supposedly enrich the mixture. The "fuel mod" was using the pressure from the intake to press against the fuel regulator and the one in the pic above is to help stop boost drop by attaching it to the actuator. The one on Ebay is being used for the "fuel mod" and not the "fume mod" as I thought earlier
Old Aug 12, 2005 | 05:04 PM
Billabong's Avatar
Billabong
Not sure about that thing on ebay, but as per Alex, the 'fuel mod' that Ahmed, Mark and a few others use, DOES work as it's meant to.
But like I say, most people don't understand how it's supposed to work (or when ), therefore say it can't work.
Old Aug 13, 2005 | 12:56 AM
JamboRS's Avatar
JamboRS
focus rs 1672
i dont know what its actually for i leave that bit to ava
as said in a previous post by me theres 2 reasons why the vac pipe goes to crossover pipe 1 is the fume mod thingy and the other is like mine goin to the amal valve,which youve pointed out as being for pressure drop
i also do have a fuel mod but that was done on the fuel ecu and metering head
steerfromdarear
28
Jan 29, 2016 06:14 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Ellsa
Aug 9, 2015 07:03 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
