Piston ring question!
Old Aug 11, 2005 | 08:14 PM
pee vee's Avatar
pee vee
Default Piston ring question!
the piston rings need to be spaced so that the end gaps on the rings
are at 120 degrees from each other.
HOWEVER
the oil control ring on engines
(im thinking Zetec here but i'd like to know for cosworths too)
the oil control ring is in 3 pieces.. Do you space the
3 seperate layers of the oil control ring at 120 from each other too??
OR do you count the oil control ring as 1 piece and therefore only
1 end gap??
(so just put it at 120 degrees from the other 2 end gaps in compression rings.)
Sorry i dont know if my question is very clear lol
ARE Cosworth YB oil rings 1 piece or 3 piece like zetecs etc?! thanks!!
Old Aug 11, 2005 | 09:27 PM
pee vee's Avatar
pee vee
ahem!
apparently they changed from the early zetecs and oil rings are now 1 piece..
DOES this apply to cosworth YB engine too?
the drawings/pics ive seen of them seem to show oil rings as 1 piece.
thanks
Old Aug 12, 2005 | 08:04 AM
JesseT's Avatar
JesseT
Usually instructions for 3-piece oil control rings tell to space them 90 degrees apart.
Nov 1, 2015 06:53 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
deathrider666
Sep 28, 2015 06:12 PM
