your opinion
Old Jun 27, 2004 | 02:48 PM
extra17's Avatar
extra17
Default your opinion
as some of you know i started stripping my saff many many months ago now to have all the underside painted and so forth
now in the next couple of weeks it will be going for painting then ill start rebuilding it again
now heres the question
every nut and bolt i strippped off the car, i can buy in stainless steel as i work in an engineering back ground
i know how it would look with every single bolt on the car being done in stainless but can anybody thing of any problems
i.e strength wise compared to the high tensile ones ford used
im just after a few opinions
thanks gaz
Old Jun 27, 2004 | 02:55 PM
dave cos4x4's Avatar
dave cos4x4
Surley you can get high tensile stainless ones.
them nuts are fookin expensive from Fords though. and you would want loads. .
Are only going to get dirty again though.
Dave.
Old Jun 27, 2004 | 02:56 PM
extra17's Avatar
extra17
aint gonna get dirty
so should i ,or shouldnt i dave lol
Old Jun 27, 2004 | 03:00 PM
Rene's Avatar
Rene
dont know the awnser bit i would sure do it not only will they look nice but when they are dirty they will stay ok
dave cos4x4
Not taking it out then when all done.
If you can get then the same strengh then why not,i'm sure you can get the stainless ones cheaper than getting Fords to supply them.
You know you really want the s.s ones anyway.
Dave.
Dave.
Old Jun 27, 2004 | 03:12 PM
extra17's Avatar
extra17
i do i do i dooooooooooooo ooooooooooh
Old Jun 27, 2004 | 03:14 PM
Phil's Avatar
Phil
Jeebus
I wouldn't bolt the beam/diff up with stainless ones, especially on a 4x4!
Old Jun 27, 2004 | 03:17 PM
extra17's Avatar
extra17
well thats tells me a lot doesnt it phil
i asked for explanations,which is what you havent given
dave cos4x4
He can Phil because he won't be going out in it in case it gets dirty.
Dave.
Old Jun 27, 2004 | 03:18 PM
extra17's Avatar
extra17
dave
flurk off!!
Old Jun 27, 2004 | 03:19 PM
Phil's Avatar
Phil
Jeebus
I don't even think you'll be able to torque a stainless bolt up to the factory settings on the rear beam..
Personally things like are not worth risking, if you launch it and a bolt gives way, or you hit a pot hole and a swingarm falls off - not worth thinking about!
Perhaps you can chrome dip the standard bolts (well the heads anyway??)
Old Jun 27, 2004 | 03:20 PM
extra17's Avatar
extra17
hmmm this is what i was concerned about
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
Topjoe9
Sep 12, 2015 09:50 AM
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
