running on three!!!!!!!!!!!!!!!
Old Aug 9, 2005 | 05:36 PM
cul's Avatar
cul
Default running on three!!!!!!!!!!!!!!!
I have a wierd prob.
after i give my rs a good hammering the car seems to run on three cylinders.
BUT!!!!!
When i pop the bonnet and disconnect the HT lead from cylinder3 and slightly touch the lead of the top of the spark plug, then it will fire up the cylinder again.
when i connect it properly again it goes back to running on three.
New Leads and new plugs being used.
would leaking valve seals have anything to do with this???
cheers
Old Aug 9, 2005 | 05:45 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
has to be lead or plug if it gets better and worse when u tamper with it
could have a dodgy lead even if it is new
try a old 1 in its place to see if it fixes itself
Old Aug 9, 2005 | 05:55 PM
cul's Avatar
cul
i got new leads and plugs because this was happening and still now its happening on cylinder 3
Old Aug 9, 2005 | 10:29 PM
GrimmeRS2K's Avatar
GrimmeRS2K
checked the dizzy end?
`spotty
Sep 25, 2015 11:41 PM
dombanks
Sep 21, 2015 08:38 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
