Rs Turbo cutout
Right i was coming down the motorway and the car just stalled
tryed turning it over and it just turned over but dont start i checked the cambelt and it was fine towed the car home put some petrol in primed the pump a few times and it started for about 5-10 seconds then cut out again tryed to start it a few times after that but nothing im thinking its a fuel problem as it did start then cut out or could it be a relay or something else anyone got any idears
From: brum/shropshire drives:- frst / escort cossie
fuel safety shut off ??? locks the pump out all RS's have them could be that in the fiesta's there in the sill panel on pass side maybe in the boot on the escorts i think??
it did start when i got it home after i primed the pump a few times it stated and run for about 10 seconds then cut out
ill give the relay a try first see if thats the problem
JK12
33
Apr 26, 2021 12:09 PM
