Cossie ISCV...????
Old Sep 10, 2005 | 01:21 PM
2wd's Avatar
2wd
Default Cossie ISCV...????
Hi, is it correct that you should "reset the idle speed", when you replace the ISCV ? (ref. a Thread from the RSOC)
If so, how do you do it ???
Old Sep 10, 2005 | 03:11 PM
Dave Henshall's Avatar
Dave Henshall
shouldnt need to, no.
you can check it though , easy enough , let itr get up to temp, disconnect the idle valve and ajust the base idle speed to 850 via the screw under the inlet on the throtle body, clockwise goes slower.
Old Sep 10, 2005 | 04:45 PM
2wd's Avatar
2wd
Ok..I will check it..
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
