Anyone got a Picture of a "GRP A" Sleeved wheel nu
Old Aug 7, 2005 | 04:26 PM
Ryan's Avatar
Ryan
Default Anyone got a Picture of a "GRP A" Sleeved wheel nu
Well not GRP A but thats what everyone seems to refer to them as
cheers
Ryan
Old Aug 7, 2005 | 05:32 PM
RichardPON's Avatar
RichardPON
Yes.
2 secs, I'll dig out a piccy........
Old Aug 7, 2005 | 06:41 PM
marco polo's Avatar
marco polo
Ryan
this what you mean
Marco
Old Aug 7, 2005 | 06:45 PM
Disabled Account's Avatar
Disabled Account
Marco, can you sell me 16 of those please? Fairly sure I need them for these wheels:
Old Aug 7, 2005 | 07:25 PM
Rippers's Avatar
Rippers
Monte Geek
Not quite as bling
Old Aug 7, 2005 | 07:30 PM
kevmk2's Avatar
kevmk2
Mine are the same as Paul R's ones. They are called grp4 conversion nuts. Well they are on mine as i have grp4 type wheel but with normal wheel studs. West wales rally spares do them for about Ł2.80 each
Marcos ones look like the ones for mk2 escorts with RS 4 spoke alloys
Old Aug 7, 2005 | 08:45 PM
NUTS RuS's Avatar
NUTS RuS
Doug Marco's are on the Rally Design website at Ł1.30 each
SN30 I think
Old Aug 7, 2005 | 08:49 PM
Rippers's Avatar
Rippers
Monte Geek
Can you get light weight versions of these? mine weight loads
Old Aug 7, 2005 | 11:30 PM
marco polo's Avatar
marco polo
Doug
just get Brom to order you some in
next day delivery
marco
Old Aug 8, 2005 | 12:04 AM
Ryan's Avatar
Ryan
marco can you measure that washer for me please mate?
got a bit odd situation.
could you tell me inside and outside diametre.
Cheers Pal
Old Aug 8, 2005 | 07:29 AM
RichardPON's Avatar
RichardPON
Doug,
Can you sell me 4 of those wheels in 17" please?!!!
Old Aug 8, 2005 | 09:22 AM
Ryan's Avatar
Ryan
bttt.
OR anyone else that can measure those washer.
is grp A 16mm OD and normal studs are 14mm?
Ryan
Old Aug 8, 2005 | 11:55 AM
Ryan's Avatar
Ryan
anyone
Old Aug 8, 2005 | 02:56 PM
Matt's Avatar
Matt
mine have no washers
and pic was taken ages ago so no im not removing it to measure it
Old Aug 8, 2005 | 03:43 PM
ian sibbert's Avatar
ian sibbert
Ryan,
Normal studs are M12 x1.5..grp'a' wheels are bored at 18mm to sit on a sleeve with a M14 x 1.5 stud the grp'a' nuts as everyone is calling then are od 18mm id is standard m12, whats the problems you have?
I have loads of these nuts going spare if someome wants some....
Regards
Ian
Old Aug 8, 2005 | 03:51 PM
Ryan's Avatar
Ryan
Ian,
basically i've been offered some bells which are off a rally car so the stud hols are bored out to 18mm. AP 330 bells.
The problem i have is need them at standard side to fit my centre lock hubs.
So i wanted to fit collets in the bells to make them fit. I.e either soemthing that a machine shop knocks up or something simliar.
Old Aug 8, 2005 | 03:53 PM
Ryan's Avatar
Ryan
so basically what i was thinking was taking some grp A wheel nuts down to a machine shop and getting them to cut the end off so i have a 6mm collet.
Old Aug 8, 2005 | 03:55 PM
Ryan's Avatar
Ryan
or which may be easier, but some 18mm alloy rod and get it hollewed and chopped to lengths buy the machine shop.
Old Aug 8, 2005 | 04:09 PM
ian sibbert
decent alloy rod would be easier imo, shame your not closer could have knocked em up in no time, could you not sleeve the wheel studs with an interference fit sleeve made of steel? or do you want to use different wheels at diferent times?
Old Aug 8, 2005 | 04:17 PM
Ryan's Avatar
Ryan
i can send you the bell ian? Its a bog standard bell though? i.e i could give you all the necessary measurements?
its pretty simple what i want. I need a washer the same thickness as the bell and with a OD of GRP A and an internal OD of a standard wheel stud.
So in essense i need metal "hola hoops" pmsl
Will be using 2 different sets of wheels on minw. Slicks & Road.
Old Aug 8, 2005 | 04:30 PM
ian sibbert
You need 8 of these then?
Old Aug 8, 2005 | 04:41 PM
Ryan's Avatar
Ryan
good god how did you that
but yes, if those measurement are correct then thats it
Old Aug 8, 2005 | 04:46 PM
ian sibbert
The only prob in making them may be if there is any differences bell to bell I can work off some I have here as long as yours are the same, really the fit could do with being pressed fit you dont want em moving under braking i'll knock some up this week and send em down but i'll make tight ooo er missus....
Regards
Ian
Old Aug 8, 2005 | 04:54 PM
Ryan's Avatar
Ryan
Ian the centerlock hub sandwiches the bell beween itself and the original hub.
So that would be perfect.
Let me know how much i owe you and we'll settle up once we meet
This is how the centrelock hubs mount.
Old Aug 8, 2005 | 04:57 PM
Ryan's Avatar
Ryan
Ian shall i wait till the new bells turn up so i can double check measurements so i dont waste you time?
Let me know.
Cant say it enough mate, your a legend
Old Aug 8, 2005 | 05:02 PM
Ryan's Avatar
Ryan
unless ian, youv'e got some spare 330 2wd bells up there
and i'll buy them off you
or if you can knock some up cheap enough
Old Aug 8, 2005 | 05:04 PM
Fozy's Avatar
Fozy
Doug, if your putting them on you escos you certainly will as that's what i needed for mine.
Old Aug 8, 2005 | 06:53 PM
Matt's Avatar
Matt
bling hubs shite mobile
Old Aug 8, 2005 | 07:04 PM
Eagle's Avatar
Eagle
Super Moderator
Old Aug 8, 2005 | 07:11 PM
Ryan's Avatar
Ryan
its a phone mate, it makes calls thats all it needs to do
but true.
tis a shite phone
Old Aug 9, 2005 | 11:05 AM
Disabled Account
Marco, Tony (nuts) and Richard Pon thanks for the replies.
Ponster, my wheels are not for sale but I will PM you the details of the chap that I purchased them from. He has approx 30 of them for sale with tyres (Perrelli rally slicks and intermediates).....He is quite expensive, and a pain to deal with also, he wants to sell the wheels WITH tyres only..........at approx Ł 200 each......worth a try IMO, especially if the slicks are of use to you.
All mine are shot blasted and ready for painting now:
JK12
33
Apr 26, 2021 12:09 PM
steerfromdarear
28
Jan 29, 2016 06:14 PM
borboyous
Aug 22, 2015 11:17 AM
Churtz
Aug 3, 2015 08:19 PM
