Missfire under boost.
Old Aug 7, 2005 | 02:56 PM
KSA-Cossie's Avatar
KSA-Cossie
Default Missfire under boost.
On my 4x4 saph if i plant the throttle it'll miss slightly but if i let the revs build slowly 85 % of the time it's ok any ideas troops ?
Old Aug 7, 2005 | 05:27 PM
phil4x4saph's Avatar
phil4x4saph
I dont know the answer but mine does exactly the same thing!
Old Aug 7, 2005 | 05:39 PM
Stu @ M Developments's Avatar
PassionFords Creator
Plug gaps and or ignition HT issues usually.
Old Aug 7, 2005 | 05:55 PM
Stoo's Avatar
Stoo
Id say plugs awell,same thing was happening to my mates-Get some Champion C57's in there!
Old Aug 7, 2005 | 06:31 PM
KSA-Cossie's Avatar
KSA-Cossie
I've just fitted 071's with a 0.6mm gap,might try dissy cap and rotor arm next,thanx for the replies.
Old Aug 13, 2005 | 12:52 PM
KSA-Cossie's Avatar
KSA-Cossie
Traced the fault to a dirty tdc sensor,all fixed now thank fook.
Old Aug 13, 2005 | 12:57 PM
Old Aug 13, 2005 | 01:04 PM
KSA-Cossie's Avatar
KSA-Cossie
Stu while your on can i pick your brains m8 ? I have a superchips stage 3 chip in my car which was done by the previous owner,would i get any benefit from buying and using one of your chips ?
timsrs
Nov 13, 2018 11:48 AM
blackbeautyzetec
Aug 29, 2015 02:11 PM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
ginger1979
Jul 31, 2015 09:56 PM
FletchCossie
Jul 19, 2004 08:17 PM
