who builds Low comp bottom end
Old Aug 5, 2005 | 11:07 AM
twinkle_2k86's Avatar
twinkle_2k86
Default who builds Low comp bottom end
who builds low comp bottom ends for the Rs turbo??
any contact numbers etc would be a great help.
thanks
Old Aug 5, 2005 | 11:11 AM
mart.rs's Avatar
mart.rs
where you from mate?
Old Aug 5, 2005 | 11:12 AM
twinkle_2k86
im from Hampshire.
Old Aug 5, 2005 | 11:24 AM
mart.rs's Avatar
mart.rs
well the only person id reccommend (and you may have seen him in peformance ford) is dean from shephard motors in chelmsford essex tel no (01245-477999)
he built me a low comp bottom end for around 800 quid bearing in mind that was a few years ago but i dont think the price is that much different now,i had that ,a cossie 2wd turbo 48 housing,bayjoo chip, ap paddle clutch,-31, and the head was left standard ,and that was running around 220-225 holding 20 psi and believe me it was so quick i only gave it some just to listen to the jet engine sound that came from the exhaust,give him a bell in my opinon hes the daddy,sometimes he does get busy so if so just call him back! just say you spoke to martin from colchester who had a white s2
Old Aug 5, 2005 | 07:14 PM
twinkle_2k86
Cheers mate, i will give him a bell. im only really after one piston machined up as i think thats what my bottom end is (a low comp set up) so i will need a special piston made to the same spec as the others.
JK12
33
Apr 26, 2021 12:09 PM
Rsmat
63
Sep 25, 2015 12:11 PM
gavt123
Sep 5, 2015 10:03 AM
KW-rscos
11
Aug 31, 2015 01:51 PM
ekjim
Aug 17, 2015 08:57 PM
