7 speed dog engagement 4WD gearbox
Super Moderator
to all that have replied,the handbrake release is not needed unless you have a rally car and do a lot of handbrake turns
I have located a tail housing and step off gears,as the origonal parts are being used on the new 6 speed
Super Moderator
Originally Posted by TF Rallyesport
what ratio step off gears?
have you checked the input shaft?
Super Moderator
Super Moderator
i didnt know/think he stocked bits for ff's?
so its £3500 fully rebuilt with new bearings and dog rings.
if your going to ford fair are you able to take it with you?
Iam not going to Ford fair but if its done over the weekend and the other guy dont have it for any reason your passing me so call in,I presume you have your moblie with you over the weekend
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
