water hose
Old Aug 2, 2005 | 07:04 PM
need4speed's Avatar
need4speed
Default water hose
hi , my hose that goes from the radiator top up tank to the turbo keeps splitting at the turbo end.should the hose clip be done up really tight or do you alowe for expantion, because after i do up the clip its fine but a couple of hours later its cutting into the hose. can this hose be replaced with aftermarket hose ,because it s thicker at the tank end than the turbo end.cheers. oh its a sapp cossie4x4[/img]
Old Aug 2, 2005 | 10:38 PM
daz1968's Avatar
daz1968
I have mine done up tight, I would suspect the hose needs replacing maybe the rubber has gone brittle with age and heat.
Old Aug 3, 2005 | 06:44 AM
Chris Honeywell's Avatar
Chris Honeywell
M8 get an uprated hose samco etc
then all will be fine
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
