what to do
Old Jul 31, 2005 | 08:14 PM
boost mad's Avatar
boost mad
Default what to do
i am hopefully rebuilding my engine soon to a spec not catered for by a pre programmed chip lol. after i have built the engine how do i go about driving it to a tuner to get it mapped? or is it a trailer job! also what do i do about running it in? i mean if it doesnt have a suitable chip in at the time then surely i shudnt drive it, but then u cud say it not worth getting it mapped until it has been properly run in
help
as i have no idea what to do
cheers
Old Jul 31, 2005 | 10:08 PM
Hectori's Avatar
Hectori
best is to get programmaple ECU, so you can tune your engine. Megasquirt is maybe the cheapest choise. you can get pretty good tune by yourself, when you use wideband lambda to check the mixtures, then just modify your Ecus programming accordingly.
if using just new chip, then i would take car to tuner with trailer. and again to check mixtures when drived 2-5k miles, if you dont have Air/Fuel Ratio gauge.
Old Aug 1, 2005 | 12:15 AM
boost mad's Avatar
boost mad
sorry i dont no much about the ecu side of things. does this run along side the normal ecu?
Old Aug 1, 2005 | 03:02 PM
JamesH's Avatar
JamesH
Build it, and give Karl @ Norris Motorsport a line and tell him the spec, he will send you a running in chip, and then once run in take it to him to be live mapped
It's the only way Alex
Old Aug 1, 2005 | 09:09 PM
boost mad's Avatar
boost mad
cheers guys
