EFI HELP
Old Jul 29, 2005 | 11:06 PM
DaveN's Avatar
DaveN
Default EFI HELP
Can a EFI CVH inlet manifold with XR2i/Fiesta RST throttle body (including Throttle Position Sensor).
enable you to convert your S1 or S2 Escort RS Turbo to run either Cosworth or Fiesta RS Turbo EFI engine management, or would it need to be the FRST one used.
Many thanks - Dave
Old Jul 29, 2005 | 11:07 PM
Red16's Avatar
Red16
as far as im aware the xr2i inlet and fiesta turbo inlet manifolds are the same
Old Jul 31, 2005 | 07:33 AM
JesseT's Avatar
JesseT
Everything is the same (XR2i vs. FRST) for except the loom, ecu, map-sensor and inlet air sensor.
Of course I'd always advice to use a completely different management...
mk1turboestate
Dec 2, 2015 08:31 PM
liamT74
Sep 23, 2015 10:24 PM
davidfordrs
Sep 21, 2015 04:23 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
