Focus air-con problem
Old Jul 28, 2005 | 07:32 PM
plynchy's Avatar
plynchy
Default Focus air-con problem
Dunno if anyone else has this problem,but the air-con seems to be on permanently. If you move the temp. knob to full cool you get icy air out of the vents with the air-con light off,even if its boiling outside.
Now i thought that with the light off,putting the knob to cool would just bring in air at the outside temp,like a normal(old) car does.
Also when you turn the engine off,every time there is a noise of what sounds like a rad. fan slowing down,even if the engines only been on for 2 minutes,is this the air-con compressor?
Need some help here peeps!
Old Jul 28, 2005 | 08:04 PM
focusv8's Avatar
focusv8
The engine management puts at least one of the radiator fans on as soon as you put the air con on, and switches off when the condenser has cooled down, even if the engine is off, so you CAN hear a fan slowing down when you switch off.
The compressor is engine driven, it stops as soon as the engine stops.
The control of A/c is done by engine management, either the A/c compressor clutch is stuck or the control of it is U-S.
Old Jul 28, 2005 | 08:29 PM
plynchy's Avatar
plynchy
So it sounds like the air-con is on permanently then? Even without the green light on on the dash. Bit weird innit?
Any remedy for it? Or is it a dealer fix?
Old Jul 28, 2005 | 08:44 PM
AndyRST's Avatar
AndyRST
can you hear a clunk from the engine when you press the air con button ?
Old Jul 28, 2005 | 09:25 PM
NathR's Avatar
NathR
Air con comes on automatically when your heater knob is set to screen mate, and no, the light doesn't come on. If when you stop the engine the fan is still going then it's a good sign air-con's been on, bit strange!
Old Jul 28, 2005 | 09:53 PM
plynchy's Avatar
plynchy
Nope,not even a dip in rpm as you would expect.
Which knob? The one that controls the fan or the vent direction? It's a bit shite that tho,you want to demist the screen so the air-con is on,even if the temp is set to hot? WEIRD.
Old Jul 28, 2005 | 10:08 PM
NathR's Avatar
NathR
The vent direction mate, the reason being air-con helps clean the screen quicker.
Old Jul 28, 2005 | 10:38 PM
Tigran's Avatar
Tigran
Thats because you are probably pointing it at the windscreen - the air-con switches on automatically - without telling you.
*edit* *must.read.rest.of.thread*
Old Jul 28, 2005 | 10:43 PM
danja's Avatar
danja
no way : So that wud explain near frost outside my window on the way home then lol
wondered why the engine clunked when I got in it at work, then half way home it all went misty/icey toward the bottom of the windscreen.
Wow, cheers for that info, never knew that
Old Jul 29, 2005 | 06:43 AM
foreigneRS's Avatar
foreigneRS
Testing the future
you wouldn't expect the revs to drop when the compressor clutch engages - as the engine management knows it's about to come on and produces extra torque to balance it.
and a/c is the fastest way to clear a screen due to the dehumidifying effect.
Old Jul 29, 2005 | 08:55 AM
Law's Avatar
Law
same happened to my Rover that im driving at the mo.
most irritating
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
jaysoc1
Aug 20, 2015 08:18 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
taylora1409
Aug 12, 2015 12:06 PM
