2.0 Si problems
Old Jul 28, 2005 | 06:59 PM
Luke_si's Avatar
Luke_si
Default 2.0 Si problems
Hi All,
I have done the 2.0 conversion and have so for some weeks now but i am having problems.
I have changed over to the 2.0 injectors and thottle body and so on but not the fuel pump! I have a K&N induction kit and running the DEEP code ecu. and using the 1.6 si gearbox
It seems to be running slow i draged with a XR2i and it keeped nose to nose with me ooh: only just though. LOL
Is there any thing i can try and look at it also lags every now and again in first gear and i dont seem to get much power after 5000 rpm
Some people have said some things but i thought i ask on here
Thanks for any replys Luke.
Old Jul 29, 2005 | 05:31 PM
sailorbob's Avatar
sailorbob
Are you using the 2.0 MAF?
Old Jul 31, 2005 | 09:08 AM
Luke_si's Avatar
Luke_si
Yes m8 but i am not sure if its the right one for the code ecu i am running i am running the Deep ecu.
Old Jul 31, 2005 | 09:24 AM
sailorbob's Avatar
sailorbob
2.0l MAF is the same for DEEP, DEWY, DESK and EARS ecu's.
Any chance of getting an error code reader on it?
Old Jul 31, 2005 | 11:31 PM
Luke_si's Avatar
Luke_si
no because i dont know were i can use one m8.
Old Aug 1, 2005 | 09:45 AM
sailorbob's Avatar
sailorbob
Most garages have one but they will probably charge you for the 10 mins (ish) it takes. Is your MAF clean? There are known issues with the oil from the likes of K&N filters contaminating the wires of the sensor.
Old Aug 1, 2005 | 01:28 PM
Luke_si's Avatar
Luke_si
i dont know what do u recomand cleaning it with please.
Old Aug 1, 2005 | 05:39 PM
sailorbob's Avatar
sailorbob
Electrical contact cleaner is what most seem to use, sprayed liberally onto the wires a few times. Don't be tempted to brush the wires as they are so fine the would probably break.
Old Aug 1, 2005 | 08:59 PM
Luke_si's Avatar
Luke_si
ok i try that.
Would brake cleaner work at all m8.
Old Aug 1, 2005 | 09:51 PM
sailorbob's Avatar
sailorbob
I'd probably try it if I had no electrical cleaner
Old Aug 24, 2005 | 10:16 PM
16vzetec's Avatar
16vzetec
has it got a cat?
maybe a fauly hego sensor?
Old Aug 25, 2005 | 08:47 AM
sailorbob's Avatar
sailorbob
The HEGO sensor isn't used at WOT so this shouldn't be the problem unless the HEGO's caused the adaptive learning to really skew the fuel correction way off. Not heard of this happening though.
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
nico12
Dec 31, 2015 04:42 PM
jonnyenglish
Sep 21, 2015 07:31 AM
BENJAMIN_21
Ford Fiesta
Sep 17, 2015 08:58 AM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
