Update on C20XE
Old Jul 27, 2005 | 12:26 AM
Snowy_Astra's Avatar
Snowy_Astra
Default Update on C20XE
Been slowing up recently has this project Money is an issue (isn't it always?!)
Few pics of my head and block fresh from the machine shop
Block: Bored out to 86.5mm. Had to do it to start with a fresh bore as the hone i had left ring wear marks which were not acceptable, and not worth the risk running the engine with.
Its also had a lick of paint, and an acid bath to strip it of all the crap it had on it. It also had a reface
The head has come along nicely, all rebuilt, casting marks ground out, reseated valves, new oil seals & new gaskets all round, skimmed and tested
Gonna be a bit of a slow one i'm afraid, so this thread will slip. I'll revive it with big updates
Still loads to go:
Supercharger
Cometic gasket
Bearings (mains and big end)
Alternator bracket (for front of engine) Almost done
YB inlet to suit XE head (picking up tomorrow hopefully)
Once i got those bits i can start rebuilding it, which i can't wait for as seeing it in bits makes it look like nothing.
Old Jul 27, 2005 | 08:49 AM
newby's Avatar
newby
ahh brings back memories seeing that xe.i used to have an astra gte 16v tuned to a high spec,remember going on a forum called migweb just for vaux fanatics.i used to have a sbd prepared xe,on 42mm tb's-tapered,running mbe management,omega pocketed pistons,sbd rods,bronze guides,sbd valves,and some qed cams,mapped by sbd-i think it was putting out 230 bhp back then[4 years ago]
Old Jul 27, 2005 | 10:03 AM
Snowy_Astra
cool Got any pics?
Old Jul 28, 2005 | 02:09 PM
Snowy_Astra
Ok, heres a quickie, but a biggie as its taken a while to have it done
Its only tacked in place ATM, i had to go and see it today and make sure all is well
Old Jul 29, 2005 | 04:42 PM
Snowy_Astra
Not that anyone seems interested, but the manifold cost me Ł100. Not too bad, was expecting it to be more
Old Jul 29, 2005 | 07:15 PM
rsnissan's Avatar
rsnissan
looking good dude
Old Jul 30, 2005 | 01:24 AM
Snowy_Astra
Yaaaaay! A reply!
See, there is a bit of ford (spit) in there
Old Jul 30, 2005 | 11:22 AM
BlackSaff's Avatar
BlackSaff
Just seen this post mate and it looks like your doing a top job, as i don't want to Hijack your thread i've PM'd you some pics of the engine build i'm doing for my brother with his C20XE.
Old Jul 30, 2005 | 02:22 PM
Snowy_Astra
Cheers NOSRSt, pics look fantastic, and those pistons are pure sex, as are the TB's and pullies
Old Jul 30, 2005 | 08:13 PM
L33 BYT's Avatar
L33 BYT
Is yours a Mark 2 or 3. I'm tempted to do a chop for a Mark 2 GTE 16v
Old Jul 30, 2005 | 10:16 PM
Snowy_Astra
Its a MK3 astra 1.4 Merit with a 2 litre 16v redtop
A chop? what sort of chop?
Old Jul 30, 2005 | 10:21 PM
L33 BYT's Avatar
L33 BYT
Pork! Sorry.
Just been keeping my eyes open for mk2 16v was gonna ask you if you had a mark 2 if they were any good?
Old Jul 30, 2005 | 10:30 PM
Snowy_Astra
No, but i've had a bash in a MK2 GTE 16v and the handling leaves a lot to be desired
Driving them in a straightline gets your confidence up thinking that its quite sterdy and stable, soon as you hit a roundabout or bend a touch over what you would expect it to go round at, it lets you down by sliding the rear out. Also there's bucket loads of lift off oversteer, i mean SHITLOADS of the stuff
If you're after an astra go for either a MK1 or a MK3
Old Aug 1, 2005 | 07:08 PM
Snowy_Astra
Well, here it is Still needs some tidying up and it should be fine
One problem, am hoping someone on here can help I need a slimline fuel rail with the inlet and outlets on the ends of it and it needs to be adjustable to fit my injectors. Anyone got any ideas please?
TPM961
Jan 15, 2018 10:50 AM
pabloXR
Sep 21, 2015 12:42 PM
