2.0 cams into 1.8 zetec
Old Jul 26, 2005 | 04:22 PM
JimmyFlo's Avatar
JimmyFlo
Default 2.0 cams into 1.8 zetec
Just been reading through this months fast ford and it has a tech guide for putting 2.0 cams into a 1.8 zetec and claims gains of 15-25 hp is this the case?
Old Jul 26, 2005 | 05:19 PM
16vzetec's Avatar
16vzetec
the 2.0l cams are supposed to be the same as 130spec cams although im not 100% sure that they are.
i believe the inlet cams have a different code but to be honest they cant be far different.
exhaust cams are the same i understand.
the advantages will only come when fitting all the 130 spec gear.
105 to 130 consists of cams/ throttle body and ecu.
so i suppose you could see 5-10 hp with just the cams.
you wont get 25hp increase unless you have the lot.
pm me for info and some spares.
if you have 115 spec then you are only 15bhp off anyway.
Old Jul 27, 2005 | 11:14 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
as mike said, you need all the stuff to get the most out of it
ps it was me in the pics/wrote the feature
BENJAMIN_21
Ford Fiesta
Sep 17, 2015 08:58 AM
talon1
Sep 15, 2015 10:27 AM
grishenko45
Sep 9, 2015 12:58 PM
BRAM
Sep 8, 2015 07:11 AM
little bram
Sep 7, 2015 11:59 AM
