stud and nut kit
Old Jul 26, 2005 | 12:10 AM
supatune442's Avatar
supatune442
Default stud and nut kit
Im having problems with my cossie head lifting,its running a T35 at approx 26 psi (410 bhp) runs lovely but on a recent track day overheated .I know its the head lifting when driven hard for long periods,ive just bought an ARP stud and nut kit ,not used them before are
they a waste of time ,should i just go for the proper long stud conversion or will they hold head down ,boost peaks at 29 holds 26 psi.. your experiences and advice are welcome..
Old Aug 5, 2005 | 06:44 PM
tomsxr3i's Avatar
tomsxr3i
for the psi that u r running u need to go with studs and nuts as these are not stretch bolts
the standard one are stretching on the boost u are running change to studs and nuts and problem solved
Old Aug 5, 2005 | 08:32 PM
Rs1's Avatar
Rs1
If used correctly a stud and nut kit will provide a better,more equal and more acurate torque down. When using stud and nuts you must ensure the thread are oiled before fitment and the block threads must be perfectly clean and dry. Also if using a metal gasket you must make sure the block face and head are straight and clean as the metal gaskets are very unforgiving with imperfection.
Old Aug 6, 2005 | 08:44 AM
july1's Avatar
july1
I'have ARP fitted but I'm only on stage 3 (330bhp) it does the job perfectly.
But for more power it may be smart to go with the long studs. I already saw broken blocs around the treads for the studs. I guess 400bhp is about the limite where both can by used so you will get all and nothing to help your choice!
If your plan is to stay in this stage for a moment fit your ARP kit. if you want more power then you'll replace it with long studs when rebuilding/upgrading the engine.
another good point will be to fit a Cometic head gasket with the ARP or a WRC with the long studs
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Cosnada
Jan 7, 2016 05:30 PM
