Central locking stopped working :(
Old Jul 23, 2005 | 10:03 PM
swanny's Avatar
swanny
Default Central locking stopped working :(
Hi ya guys,
I have remote central locking on my F plate S2 (via a random maked alarm) went to lock the car tonight and the central locking isnt working
I can manually lock both doors by key, however the drivers door will not unlock from the outside (I am not sure if this has been the case for a while, as I normally always use the key fob rather than manually locking the car).
A very quiet "click" noise can be heard from inside the car (possibly coming from around the drivers side footwell) when u attempt to lock the doors via the key-fob.
Ideas ???
Cheers, Swanny
Old Jul 23, 2005 | 10:53 PM
Ven0m's Avatar
Ven0m
ive got this problem as well m8 hope someone has the solution, in my case its the locking part the alarm wont do, it will bloody unlock it
Old Jul 24, 2005 | 12:19 PM
JamesA_RST's Avatar
JamesA_RST
the clicking noise from the footwell will be the remote locking relay, check the fuses, also a common fault is the earth wire behind the drivers side speaker, the wires running between the car body and the door can sometimes break as well, check all these things, its just a matter or elimination!!!
Old Jul 25, 2005 | 04:47 PM
swanny's Avatar
swanny
TY james, i'll get to it
JoeyBoyden
Jan 4, 2024 02:36 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
Red_bull
Aug 9, 2015 08:34 AM
