whats after stage 3
Old Jul 23, 2005 | 12:46 PM
gobble's Avatar
gobble
Default whats after stage 3
i,ve half stripped my 2wd engine down after running stage 3 with rs500 intercooler and t35. how much more will this block take should i keep this block or start off with a 200 block with the view to more power later on
Old Jul 23, 2005 | 05:24 PM
Kam B's Avatar
Kam B
mate run low compression pistons it will handle the power
Old Jul 23, 2005 | 09:59 PM
cossie604's Avatar
cossie604
I think after stage 3...most ppl go up to stage 4 lol jk After a stage 3, tuning can take so many different routes to acheive the same goal. Choose 1 route and stick to it, dont mix and match different tuners methods...it wont work long term. But low comp is deffo gotta be part of your next step...need that with this countries poo fuel octane rating
Old Jul 24, 2005 | 03:28 PM
wildheart's Avatar
wildheart
4x4 pistons to give lower slightly lower comp and ported head with cams,greys and remap
Should be knocking on the door of a nice useable 400bhp
Old Aug 1, 2005 | 03:18 PM
JamesH's Avatar
JamesH
Get propper advise from an engine builder/mapper but do all the work yourself
Old Aug 5, 2005 | 08:50 AM
newbie18's Avatar
newbie18
Err stage 4! t4 turbo bigger boost, bigger injectors new map etc etc
Old Aug 10, 2005 | 01:02 PM
cossie604's Avatar
cossie604
^^^^ copy cat
Old Aug 16, 2005 | 04:34 PM
cozzie4d's Avatar
cozzie4d
As others say, there are lots of options. It depends on your goal.
I believe >400bhp means porting/flowing the head, and more then >430bhp or something also means other inlet/outlet cams (BD10/14) I think.
It probably also depends on what you're renewing when rebuilding (all new ARP bolts for big power, big end ald main stud; high pressure oil pump; good headgasket; 044 fuel pomp for more flow etc.)
Good luck
JK12
33
Apr 26, 2021 12:09 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
A.t.p
Sep 29, 2015 05:04 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
