Help Needed!! PLEASE
Old Jul 21, 2005 | 03:04 PM
Andy_RS's Avatar
Andy_RS
Default Help Needed!! PLEASE
Im having trouble with my `89 RS Turbo!!
Its difficult to start n when it does eventually fire up it refuses to idle properly!! Its sparking fine n it is fuelling when the metering flap is pushed down.
Iv disconnected the cold start which made no difference, iv disconnected the multiplug on the side of the metering head which again made no difference!! Iv changed the pump, accumalator, ECU and Pink fuel pump relay. Iv checked the fuse for the heated seats n its ok. Im now running out of patience n cash!!
Has any1 got any idea of what else it could be or shall i just change the metering head as this is the only thing i havnt changed??
Any help appreciated!! Thanks
Old Jul 21, 2005 | 04:39 PM
Andy_RS's Avatar
Andy_RS
BTTT
Old Jul 21, 2005 | 08:52 PM
Turbo-T34's Avatar
Turbo-T34
are you running a dump valve?
Old Jul 21, 2005 | 10:15 PM
GrimmeRS2K's Avatar
GrimmeRS2K
also check the dipstick is sealed properly at the top
the hard plastic pipe what goes to the metering unit hasnt been burnt through a small hole can cause problems
any of the breathers from the rocker cover split?
take your dumpvalve off (if u run one)
cam/ingition timing out?
fuel ecu?
boost hoses split somewhere
give these a try mate
Old Jul 22, 2005 | 11:08 AM
Andy_RS's Avatar
Andy_RS
Cheers! Aint got a dump valve, dipstick sealed fine, no breathers split, boost hoses fine!!
Il check the over bits later, if there all fine will it be metering head??
Old Jul 22, 2005 | 06:48 PM
Turbo-T34's Avatar
Turbo-T34
hmmm, has a sump gasket recently been changed, or is it leaking?
If you advance or retard the camshaft, does it make it idle better? - if it does, i would guess you might have a vacuum leak somewhere.
Try turning the co2 adjustment screw on the inlet manifold, anti-clockwise i believe, this might help also.
Let us know how you get on
Old Jul 22, 2005 | 07:29 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
i had the same prob and checked EVERYTHING that you guys have mentioned and in the end it was jus a bit of water in the dizzy. sounds stupid but its worth checking
Old Jul 24, 2005 | 12:36 PM
JamesA_RST's Avatar
JamesA_RST
Yer check the Dizzy, anything in the dizzy will cause bad idle,
Old Jul 24, 2005 | 04:45 PM
KevS2's Avatar
KevS2
Have you tried the idle speed mines had a similar problem and i turned the idle about and not had any bother since!
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
