will these maps start my car?
Old Jul 19, 2005 | 05:57 PM
leecavturbo's Avatar
leecavturbo
Default will these maps start my car?
dilema is , i have a new rebuilt engine and a new engine management system that i will get mapped professionally, but i need to start the car and get it to run without it coughing and spluttering and take it to 3000rpm for obligatory running in stage,
now i don't know if the sample maps in the ecu package will suffice?
plus i need it to run to drive it to the mappers
dta p8pro.
Old Jul 19, 2005 | 06:04 PM
Billabong's Avatar
Billabong
Honest answer - I don't know, lol.
Speak to your mapper and see if they can send you a base map, based on your spec'.
Old Jul 19, 2005 | 06:15 PM
GARETH T's Avatar
GARETH T
the ignition map will be fine im sure,, the fuel map,, i couldnt guess at,,,,
just try it
Old Jul 19, 2005 | 06:23 PM
leecavturbo
doesn't the fuel map sort it self out with a lambda connected for anything less than full throttle?
Old Jul 19, 2005 | 06:28 PM
GARETH T's Avatar
GARETH T
that really depends on what system/features are on,,,and its far from full throttle
Old Jul 19, 2005 | 06:58 PM
markk's Avatar
markk
ive done abit of work with dta and find it a very hard system to try and map, ok ive no experiance with it until this project thats been happening , but ive been unable to adjust the ign/fuel real time on each individual load site, th eonly way was by a global adjustment in either a percentage or by numerical value, there are also a hell of a lot of setup procedures related to the the closed loop setup before you can use it to set up the fuelling. was considering it for my own car but after trying to use it for a friend found it very UN- user friendly - will look forward to hearing how you get on pal.
oh and as for the maps, im with bill, ign sort of ok enough-ish , the fuel all relevant to your fuel system pal
manuel boeckx
13
Oct 3, 2015 02:29 PM
track.focus'd
Aug 12, 2015 05:53 PM
Archiejay
Aug 12, 2015 12:07 PM
Adam-M
22
Aug 10, 2015 10:46 AM
sridgett
15
Aug 3, 2015 07:26 PM
