T3 oil feed inlet question
Old Jul 19, 2005 | 02:22 PM
plynchy's Avatar
plynchy
Default T3 oil feed inlet question
Just got my turbo back after pretty much a full rebuild,new bearing housing,2 new impellors,shaft,bearing,seals etc so i'm several hundred quid lighter!
Guy who rebuilt it reckons i should drill out the oil inlet socket to the same inside diameter all the way through to increase the oil feed rate through the turbo. The socket(bit the flexi pipe connects to) currently has a 4.5mm hole in the top and a 1.5mm hole in the bottom. Wise idea? anyone any thoughts on this?
I'm reluctant to do it personally as the holes are that size for a reason,if i make the bottom one bigger the flow will increase but at the same time reduce the pressure. HELP!
Old Jul 19, 2005 | 04:35 PM
Chris Honeywell's Avatar
Chris Honeywell
Well my T4 came with the hole already about 4mm
A friend of mine left his T34 with the 1.5mm hole and it destroyed itself because of lack of oil
Old Jul 19, 2005 | 04:40 PM
CraigN's Avatar
CraigN
Karl told me to drill mine out so i did
Old Jul 19, 2005 | 04:50 PM
alan rainbow's Avatar
alan rainbow
and mine but it was already done
Old Jul 19, 2005 | 05:18 PM
wildheart's Avatar
wildheart
You dont want to drill it out to same diamater though
Old Jul 19, 2005 | 05:19 PM
plynchy's Avatar
plynchy
So how big are we talking? 3mm? 3.5?
Hurry up lads cos i'm gonna start fitting it in a minute!
Old Jul 19, 2005 | 05:21 PM
wildheart's Avatar
wildheart
Mines been drilled out but dont know by how much
I know its not 4.5mm though
Old Jul 19, 2005 | 05:28 PM
alan rainbow
3mm at least
jessie_rs
62
Aug 6, 2019 09:27 PM
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
Chopshop85
Sep 12, 2015 06:42 PM
hopper350
Sep 4, 2015 12:53 AM
