Zetec Crank Pulley- Urgent
Old Jul 19, 2005 | 12:14 PM
Sunil_FiestaRS1800's Avatar
Sunil_FiestaRS1800
Default Zetec Crank Pulley- Urgent
My crank pulley has become noisey. I took he belt off and it seems to have movement. Is there a rubber damper as part of it behind or something?
Old Jul 19, 2005 | 12:16 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
no mate, if its got play its fukked, replace asap before it fooks the crank, happened to amte, no matter how tight we done it up, it still had play.
get down the scrappers
Old Jul 19, 2005 | 12:19 PM
Sunil_FiestaRS1800
Luckily i got a few 1.6 engines in the back garden. Pretty sure the cranks pulley is same will change tonight.
How will i know if its fucked the crank? If it has does that mean i need a new crank or whole bottom end or what??
Thanks
Old Jul 19, 2005 | 12:27 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
if its only just started to do it you should be ok.
basically there is a woodruff key that the pully slots on to.
if its worn it will batter the key, and can rusult in the keyway in the crank being made bigger so it will all be loose.
if its come to that (which i doubt) you will need to replace the crank.
Old Jul 19, 2005 | 12:31 PM
Sunil_FiestaRS1800
Its making a proper racket so im gonna prepare for the worst that my cranks fucked and hope to be surprised. How much is a crank gonna set me back?
Old Jul 19, 2005 | 12:41 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
lots, in all honesty, my mates was fookin noisy and we just kept graunching it up for ages, until we took it off and had a look and saw that the hole in the pulley was fooked. crank was ok, so just nailed another pulley on
Old Jul 19, 2005 | 12:45 PM
Sunil_FiestaRS1800
I hope your right. Cheers for the info
Its just my luck for it to go wrong now i only got it back on the road sunday after my alcon clutch fucked. Fitted a focus inlet now which has given it bit more grunt but has also given a few problems
Old Jul 21, 2005 | 02:09 PM
Sunil_FiestaRS1800
Sorted it now with a pulley off one of the 1.6 engines i have. Woodruff key was fine but look at the pulley
Old Jul 21, 2005 | 04:09 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
told ya
Old Jul 21, 2005 | 04:16 PM
Sunil_FiestaRS1800
told ya
told ya
Yea cheers mate
Wasnt expecting the pulley to be that fucked . Once i had seen it i thought the woodruff key was gonna be mashed but it was perfectly fine surprisingly. Proper lock tighted the fooker on now so shouldnt come loose again
Old Jul 21, 2005 | 04:18 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
glad it was fine mate
ps, i only told you once, not twice
Old Jul 21, 2005 | 05:23 PM
pee vee's Avatar
pee vee
it was mine that fudgee was on about..
couldnt work out why it kept knocking even though it was tight!!
mine didnt even appear to be fooked until we compaired to to another (good)
one!
glad you got it sorted mate.
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
BRAM
Sep 8, 2015 07:11 AM
