Priming a turbo
Old Jul 18, 2005 | 09:44 PM
rs_daz's Avatar
rs_daz
Default Priming a turbo
Hi all.
Fitted my new turbo today ..but having a few problems priming it..
Ive fitted a T piece and the oil pressure device for my gauge on the back pf the block
Took the spark plugs out and a coil lead and cranked the car over..after about 10 mins there still was no oil coming out the oil retern pipe to the sump..its new oil and new filter.
And tips?
Old Jul 18, 2005 | 09:47 PM
JamesH's Avatar
JamesH
Sometimes it does just take quite a while but 10mins does seem quite a while
Old Jul 18, 2005 | 09:49 PM
THEYGOTMETOO's Avatar
THEYGOTMETOO
CUNT!
From: BLUE PILL or RED PILL ... All I offer is the truth, nothing more, nothing less. You choose.
As above it can take ages sometimes. If I were you I would disconnect the phase sensor as well while your cranking it over.
Old Jul 18, 2005 | 09:54 PM
©hatter Box's Avatar
©hatter Box
try putting the leads and plugs in and disconnect the coil and undo the top of the oil line into a milk bottle an rs dont have a phase sensor 10 mins is far to long should only take 10 sec if that
Old Jul 18, 2005 | 09:58 PM
rs_daz's Avatar
rs_daz
How would putting the plugs n leads in rise oil pressure? dont get that
Old Jul 18, 2005 | 09:59 PM
JamesH's Avatar
JamesH
Yeah good point, when I done mine I just disconnected it from the coil rather than taking the leads out
©hatter Box
y they off in the 1st place?
Old Jul 18, 2005 | 10:00 PM
JamesH's Avatar
JamesH
Yeah leave the plugs in!!!
Why were they out?
Old Jul 18, 2005 | 10:03 PM
rs_daz's Avatar
rs_daz
Cuz i just put a new cam in and valve stem oil seals n valve springs.
Old Jul 18, 2005 | 10:06 PM
©hatter Box
u got to run the cam in for 20 mins did u know that put the plugs in and give it other go but if the cam is new u will need to sit at 2thou rpm for 20 mins to run the cam in
Old Jul 18, 2005 | 10:08 PM
rs_daz's Avatar
rs_daz
Yes I know that thanks ..but not doing it till the new turbo is primed
Old Jul 18, 2005 | 10:17 PM
THEYGOTMETOO
CUNT!
Assuming you mean an RST doesn't have a phase sensor... If so your correct, I just quickly scanned through the post and assumed Cossie for some reason
Old Jul 18, 2005 | 10:22 PM
rs_daz's Avatar
rs_daz
Taking the spark plugs out will make it crank over quicker..
Sounds like just crank it over for a long time and wait..
I might take the oil feed pipe off and check its not blocked and make sure oil is coming out the bk of the block..
Old Jul 18, 2005 | 10:32 PM
essexrsturbo's Avatar
essexrsturbo
mite be a blocked oil feed, maybe the reason it shat itself
Old Jul 18, 2005 | 10:35 PM
rs_daz's Avatar
rs_daz
Fook knows
Old Jul 18, 2005 | 11:06 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
you should of done it with the oil feed pipe off in the first place, whilst holding the compressor with long nose mole grips so it doesnt turn whilst cranking!!
Old Jul 18, 2005 | 11:19 PM
rs_daz's Avatar
rs_daz
Yeh i done that..fook all is dripping out..
I did a oil change aswell with new oil filter which hasnt helped..and just turning it over isnt enough..I was told the turbo was primed anyway..has oil in it..might have to start the car up leave it for 10 secs to get better pressure ... then take coil off and bottom oil return pipe and try it again..
Old Jul 19, 2005 | 02:11 PM
rs_daz's Avatar
rs_daz
Sorted this now...I loosened the oil filter a few turns and cranked it over with coil off..waited till oil pissed out..Tightened oil filter bk up..Then cranked it over checking oil return pipe...which we had oil pissing out!!!! Turbo primed!
Old Jul 19, 2005 | 02:17 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
seems strange that it wasnt pissing out oil before you loosened the filter.
did you replace the plugs at the same time?
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
