T34 FITTING! Ah sh*te!
Old Jul 18, 2005 | 07:43 PM
moonstone4x4's Avatar
moonstone4x4
Default T34 FITTING! Ah sh*te!
OK so i got it on finally, went to put the actuator on and to keep the wastegate shut i run out of threads on the rod!
I looked on the standard one that was on the car, and it shuts with the arm at a 5 o'clock possition. whereas my T34 shuts at a 6 o'clock possition. (have they put the arm on wrong?!)
I measured the distance between the edge on the arm to the edge of where you bolt the actuator. On the standard T3 it was 170mm. The T34 was 165mm
The actuator is a -31 and its a 4x4 sierra cos (non-cat)
Any input will be a great help.
CheeRS
Graham.
Old Jul 18, 2005 | 08:01 PM
dave cos4x4's Avatar
dave cos4x4
the turbo housing could need turning to put it in the right position etc...
May have to find a new act. bracket and then look at the position.
Needs to be as close to 90 degrees as possible to the wastegate arm.
Dave.
Old Jul 18, 2005 | 08:08 PM
Stu @ M Developments's Avatar
PassionFords Creator
The actuator sounds like its NOT actually off a T34 to me.
Probably off a T3 or similar?
Old Jul 18, 2005 | 08:11 PM
moonstone4x4
The actuator is straight, the arm is at 90 deg. it looks like the thread needs to be extended.
Should this be? Am i missing something?
Old Jul 18, 2005 | 08:14 PM
dave cos4x4
Yes, you need a longer rod then.
you can get longer rods that screw on the threaded bit.
Or just get a new actuator.
Dave.
Old Jul 18, 2005 | 08:19 PM
moonstone4x4
OH dear! so the -31 actuators of the standard T3 are different to the T34 ones?
Old Jul 18, 2005 | 08:27 PM
dave cos4x4
think its just the screw on rod that is different,can get different lengths.
Dave.
Old Jul 18, 2005 | 08:37 PM
moonstone4x4
ta chap...i'll get on the phone tomorrow.
Old Jul 18, 2005 | 08:40 PM
VERY different.
http://www.motorsport-developments.c...55a604a6559311
Click the pics for a clearer view of the differences....
Old Jul 18, 2005 | 08:45 PM
moonstone4x4
VERY different.
Thank you. much appreciated!
What one do you recomend....basically stage 3 spec -31 or -34
SmudgerByName
52
Jul 28, 2016 06:14 PM
biggiejody
Insurance
Sep 2, 2015 12:04 PM
Danielbetty
Aug 23, 2015 12:52 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Escortdriver1
Aug 19, 2015 09:02 PM
