webber/dellortos
Old Jun 23, 2004 | 06:45 PM
Chris-S2's Avatar
Chris-S2
Default webber/dellortos
Hi, does anyone no of any twin carb setups that are good for turboing? or turbo ready? I've been told webber 45dcoe's 152g are turbo ready but i was wondering if there were any down draught carbs that are compatible as space is pretty tight.
Any part numbers, links, contacts and information would be great!
It's for a cvh engine if it makes a difference.
Chris
Old Jun 23, 2004 | 08:28 PM
Chris-S2's Avatar
Chris-S2
BTTT
Old Jun 24, 2004 | 05:29 PM
Chris-S2's Avatar
Chris-S2
Any carb experts?
Old Jun 24, 2004 | 06:59 PM
richm's Avatar
richm
DCOE/DHLA type carbs for turbo use are quite specialised, they need to be effectively sealed so there's no leak to atmosphere under boost conditions, and so that the float chamber gets pressurised to the same degree as the inlet plenum to ensure consistent fuelling.
The only carbs of this type I can think of immediately is from an early Lotus Esprit, they are sidedraught, but not sure if they will be Weber or Dellorto, could easily be either.
Old Jun 24, 2004 | 07:23 PM
Chris-S2's Avatar
Chris-S2
Thanks richm
Can anyone suggest a company or a tuner on here that would be able to convert the carbs if i couldn't get hold of some turbo ready ones?
Thanks
Old Jun 24, 2004 | 08:04 PM
richm's Avatar
richm
http://www.racecar.co.uk/dellorto/
http://www.racecar.co.uk/dellorto/carcarburettors.htm
maybe worth a chat with these guys.
The Esprit used Dellorto DHLA derivative carbs not Weber.
Old Jun 24, 2004 | 08:07 PM
Chris-S2's Avatar
Chris-S2
Thank you!! I'll give them a ring tommorow and see what they say.
Old Jun 24, 2004 | 08:12 PM
richm's Avatar
richm
http://forums.turbosport.co.uk/bbs/s...lapsed&sb=5&o=
dunno if it may be worth getting involved in that discussion - someone may be able to point you in the right direction?? "Per" is a nice guy, I'm sure he would help you if he can..
