coilovers for 4x4 cossy.....
Team HOTHOT!
getting the car "ring prepped" at the moment - whats a good package for coilovers for the cossy?
been thinking Avo or Bilstein
but i've also heard horror stories about the rear strut tops coming thru and destroying the rear of the car
can anyone advise please
I have coilovers on my car and the handling is OK. It is a bit bouncy on the rebound but I can live with it. One thing to note is I only use it on occasions and I know you use it daily.
Good luck
Graham
Good luck
Graham
Team HOTHOT!
tony - my front koni dampers are well, fucked
drivers one is leaking so may aswell upgrade at this time - but i might just stick a pair of new dampers on the front and let it be
Fairy nuff mate
If your planning more ventures then it may be worth considering as like you said its an upgrade. But just to remember whats good for one may be lethal for someone else. Roads, driving style, etc etc all have an effect on the package your thinking about buying.
i think avos are prone to rusting on the threaded part as for some reason they are not galvanised/treated.
but saying that ill prolly blag a set for the 3 door when its ready as its primarily gonna be a track car, but ill still use it on the roads.
unless i can blag me some spax coil overs
Bilstein were always my favourite but I am not sure what the quality is like these days. Mine were specially built Konis BTW. I got them second hand but I knew their origin
Graham
Graham
You could just get new shocks and maybe harder springs.
i think peeps only get the coilovers on the saff if they want bigger wheels on as they might scrub the spring cup.
No real problems with mine and don't forget you can alter the height of the car and the stiffness of the shocks so can go hard for the track etc...and then soft for road again.
Dave.
Dave.
