Sump gasket leaking very bad
finally got car back on road but the bloody sump gasket has gone on both ends its a lot worse at gearbox end whats the best way to fit these as ive not used silicone just few dots superglue to hold it in place??? any other ideas as this didnt work
if not it will be going to garage as i cant be arsed to do it
might give it a go dont really want to use any sealant i see that you can get a cork gasket but its for a series 1 will this fit???? as thought they were all same engines dont no if sumps are diffrent????
cheers
jon
cheers
jon
Yes i had the same problem. The way I sorted it was to superglue the new gasket to the sump and leave it overnight and then put the sump with gasket back onto the block bedded on Hylomer, no problems since.
Colin.
Colin.
i had to do it three times before i made it seal. eventually i tried it without sealer and it was fine. IMO the sealer acts as a slippy surface for the gasket to slide about on and move under pressure. I will never use sealer again
Originally Posted by Combi_Chris
just get the job done properly, with a NEW gasket , messing about with sealer is only a TEMP soloution is it not ?
will give it a try again tomorow after work
there are two sump gaskets jon, a two piece which is early one, and a one piece,
is this a series 1 bottom end and sump u have put in? if u have fitted a series 2 sump gasket on a series 1 sump, it will leak where u have said
if u fit a proper series 1 sump gasket and yours is a series 1 bottom end, u will need a bit of sealer on the sides where the circle cut outs are
Mc5506
Oct 5, 2015 09:57 PM
