ST engine swap
Old Jul 15, 2005 | 07:43 AM
johno17's Avatar
johno17
Default ST engine swap
Hi,
I have a standard 2.0 just now.
If i was to upgrade to an ST170 engine , is that all i would need; the engine.
Can I use the original gearbox, wiring etc
Cheers for help
Old Jul 15, 2005 | 09:29 AM
sailorbob's Avatar
sailorbob
You'd probably need the ecu as the ST170 uses the Black Oak ecu (there might be loom changes too).
Old Jul 15, 2005 | 12:19 PM
BIGDOG85's Avatar
BIGDOG85
The ST170 has a six speed box so ude probably need that, and ude most probably need the loom as well
Old Jul 16, 2005 | 06:25 AM
johno17's Avatar
johno17
Ok,
Whats the loom?
Old Jul 16, 2005 | 05:37 PM
sailorbob's Avatar
sailorbob
The big bundle of wires that connects everything
Old Jul 19, 2005 | 11:40 PM
Al Bags's Avatar
Al Bags
Theres no "probably" about it ..!
Almost ALL the wiring is unique to ST170 (It's Yank) You would need 14K733 (Engine base wiring) including the hard-wired Bay fuseboard, 12A690 (Engine) and 9H589 (Injectors) Engine wiring, 12A522 from ECU to Engine/Fuseboard and Fuel Pump, plus there is a Pump pressure/volume control unit near the back, pump assy, plus box/remote .. AND you have to use the right stuff as a donor car could be (+) or (-) ESC(IVD) (Stability System)
Hope that makes your mind up for you ; )
Old Jul 19, 2005 | 11:42 PM
Al Bags's Avatar
Al Bags
Oh! .. and the Heated windscreen version of the 14K733 must be used if your car has one ; )
Old Jul 20, 2005 | 10:01 AM
sailorbob's Avatar
sailorbob
Mmmm, don't you just hate canbus sytems
Old Jul 20, 2005 | 12:01 PM
Al Bags's Avatar
Al Bags
Well .. Yes .. but the old Focus doesnt use it!
The first one to use this ... fully .. is the new Galaxy replacement ; ))
New Focus and C-Max does ... to some extent.
Old Jul 22, 2005 | 09:57 AM
sailorbob's Avatar
sailorbob
I thought implementing CANBUS was one of the reasons the Black Oak ecu was being used, or is this just the SCi Mondeo and the ST170 is a halfway affair?
Old Jul 27, 2005 | 05:38 PM
radiant red's Avatar
radiant red
in the middle of fitting a focus rs engine to a 1.6 focus . the looms are different all the way to the boot so it is quite an involved job.
Old Jul 28, 2005 | 10:12 PM
RSreplica's Avatar
RSreplica
Chris Astley Motorsport
im just about to do the conversion too. have a 1.6 zetec focus which i will transplant everything from a crashed st i bought.
so i do need to change all the loom then?
Old Jul 28, 2005 | 11:28 PM
Al Bags's Avatar
Al Bags
Yes ... Sorry ... Both cars use unique wiring.
The identifier for the RS is a 2M5O prefix on the wiring part number.
There are a few relocated items on RS, such as the Alarm (GT Alarms) module, using extended standard leads from sensors ; ))))) )
ST170 uses prefix of 2M5V on unique parts. (Which is most of it)
You need the floor wiring (14014) to connect up Premium Sub sound system for instance ; ))))
JoeyBoyden
Jan 4, 2024 02:36 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
track.focus'd
Aug 12, 2015 05:53 PM
vdubo7
Aug 2, 2015 08:17 PM
