Group A or 3 layer Cometic Headgasket ???????
Old Jul 13, 2005 | 02:15 PM
AlexD's Avatar
AlexD
Post Miester !
Default Group A or 3 layer Cometic Headgasket ???????
I will be needing an engine rebuild soon on the cossie !
I have a cometic head gasket but i am not sure if i shoudl use it or use a
standard group A gasket.
The thing that worries me is, my chip is written for a standard
2wd cossie setup, pistons etc..
But i will have new block and 4x4 pistons etc..
Will the chip be ok using a 3 layer gasket ??
Cheers ,
Al.........
Old Jul 13, 2005 | 02:33 PM
R4N SS's Avatar
R4N SS
you will need to get the car remapped after the rebuild - you cannot use your old chip unless you want to do another rebuild
The chip has to be the right spec for the car.
Old Jul 13, 2005 | 05:06 PM
Fiecos Dan's Avatar
Fiecos Dan
use cometic gasket, i've had no problems.
you will need to have the tune checked once all run in, and changed if needed.
Old Jul 14, 2005 | 07:27 AM
AlexD's Avatar
AlexD
Post Miester !
I have been told, the Chip will run fine as it was written for 98 Ron Super,
and with the slight lower compression...
Al.......
jessie_rs
62
Aug 6, 2019 09:27 PM
Nov 1, 2015 06:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
beller
Sep 21, 2015 04:13 AM
davidfox280585
Shows & Track Days
Sep 17, 2015 10:09 AM
