Revs question....
Old Jul 10, 2005 | 10:39 PM
MrsFrog's Avatar
MrsFrog
Default Revs question....
When you're cruising at say between 70 and 80 in 5th gear, what revs are you supposed to see? Mine is between 3.5 and 4K but frog's is below 3k
Also mine is a 2WD sapph and his is a 4X4.
Old Jul 10, 2005 | 10:51 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
70, just below 3k as the turbo is egging me on to push the loud pedal
Old Jul 10, 2005 | 10:56 PM
SPADGE's Avatar
SPADGE
2 things here you are putting too much faith in as to their accuracy! Rev counters and speedo's in these shonky old Fords are rarely accurate and will differ from car to car. Also wheel size/tyre size if different between the 2 cars will affect gearing and so give different readings anyway. Can't remeber what the ratio is for 5th on either the 2wd or 4wd but this would also make a difference if of course they are not the same...
Old Jul 12, 2005 | 09:02 PM
MrsFrog's Avatar
MrsFrog
Thanks, I understand.
Can I quote you on that if I am ever caught speeding tho?
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
cozzy jeff
Aug 14, 2015 05:46 PM
