BRAKES.....arrrggghhhhhh HELP - Semi floating axle and....
Fixed calipers...
Apparently there is play in the semi floating axle set-up that cause the brake disc to move on the bearing thus causing the pads to go back into the calipers.......hence why my brakes screw up...
The fix is floating rear brakes like standard 4x4 ones or having fully floating hubs at about 500 quid each side.....
Anyone know about this ?
Yep - Heard of the problem quite a few times before.
AP calipers or fully floating shafts usually solve it.
Maybe give the guys at http://www.prepfab.co.uk a quick call for some advice ??
Tony
Tony
Originally Posted by dingy
yeah its the wilwood one on my front...
so u reckon i need 2 one per caliper ? or one for both calipers ?
That would be better
I am not running AP,s on the rear
Good luck
TrevCos
Aug 22, 2015 06:05 PM
