Bhp on light blues???? step up from 803's???
Old Jun 22, 2004 | 08:11 PM
B13F RS's Avatar
B13F RS
Default Bhp on light blues???? step up from 803's???
As above......... what is the norm in terms of horse power can these injectors goto??? i'm looking at running around 25psi so need to upgrade. I've also been looking at greys but surely these would be better???
And how much would light blues cost??
Old Jun 22, 2004 | 08:36 PM
Disabled Account's Avatar
Disabled Account
KTCos,
Yes, Light Blues are the next step up from 803's (dark greens).........The light blues are also known as Motorsport 400's......very good spray pattern, and these Light Blues are often overlooked (peeps prefer to go for greys instead)......They are good for 400 BHP + a bit more with the corected fuel pressure.
Ask IMA (Phil) about cost, but dont forget you will need a chip to suit, and a good rolling road or live map session to get the set-up spot on!
On 26 LBS/PSI of boost my old Saph 4x4 with the Paul Bailey built engine made 406 BHP/396 ft/lbs torque on Interprpo rollers........I would say that the light blues are a perfect match for the T34B turbo..........But the correct set up - especially fueling is absolutelly essential
Old Jun 22, 2004 | 11:24 PM
Stu @ M Developments's Avatar
PassionFords Creator
If your actually going to BUY these injectors, then dont waste your time with 400s, go straight to 403's.
All "IMO" of course.
Old Jun 23, 2004 | 05:38 AM
B13F RS's Avatar
B13F RS
Thanks for ya advise Doug
A friend of mine is selling some cheap so thought they would be ideal to suit my set up running 25 psi. I do realise i need a chip and set up which is not a problem.
Stu....... why do ya think i should go to greys??? i do understand where ya coming from but i'm not after anymore than 380ish bhp which is what the light blues are good for?????
Old Jun 23, 2004 | 05:42 AM
MKGCMAX's Avatar
MKGCMAX
im running light blues @26 psi tailing off to 22 and they are well inside there limit car is 2wd running 375 bhp safe and reliable at that
Old Jun 23, 2004 | 06:27 AM
B13F RS's Avatar
B13F RS
Excellent mate thanks for ya input .its looking more likely me getting these cause they is well cheap
Old Jun 23, 2004 | 06:29 AM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
GREYS forget light blues
Old Jun 23, 2004 | 06:34 AM
B13F RS's Avatar
B13F RS
Why tho???? surely these are ok for what i want??
God i'm confused
Old Jun 23, 2004 | 06:56 AM
timrud's Avatar
timrud
One day you will want more, so go for the Greys.... Save yourself some money in the long run!
Old Jun 23, 2004 | 07:06 AM
swerv's Avatar
swerv
i went for light blues on my fairly standard engine(st head and cams) running 34psi at the top and about 26psi towards the top , this was a very nice conversion and would definatly have the same again!
i done 15kmls with no probs as well
Old Jun 23, 2004 | 07:21 AM
foreigneRS's Avatar
foreigneRS
Testing the future
go for em. if you're getting em cheap, you'll be able to sell them on later without loss IF you go further and need greys.
Old Jun 23, 2004 | 07:29 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
The only problem I can forsee is that you will struggle to find and "off the shelf" chip for these injectors, which means someone will have to custom map you something. Certainly avoid someone elses "custom chip" for your engine thinking it will be okay, as it may have been mapped for different cams / c/r which could cause damage to your engine by either over or underfuelling.
Old Jun 23, 2004 | 07:30 AM
I sold mine and changed for greys as they are on the VERY limit @ 380-400bhp on normal mapping...
Where as greys on on the limit @ 440, therefore you can run greys no were near the limit and have 380-400
Old Jun 23, 2004 | 08:14 AM
Dont be confused mate as my reasoning is simple.
Greys cost less than blues and are bigger and just as simple to map for perfect fuelling so why pay more for less?
If your getting them cheap then my argument is out the window, thats why i stated "If your buying them new "
Old Jun 23, 2004 | 11:42 AM
Matt's Avatar
Matt
you will be getting karl to map it wont you anyway keith? either injector type will do as both can be custom mapped. i have greys
Old Jun 23, 2004 | 04:31 PM
B13F RS's Avatar
B13F RS
I've now purchased the injectors so i'll be getting Karl to sort the chip
Can he still do them Matt if ya send the spec to him???
Thanks for ya help everyone
Old Jun 23, 2004 | 04:56 PM
BrianB's Avatar
BrianB
can you recomend anyone who does this?, i am after getting a custom chip and rr setup,
how much does this typicaly cost?
Old Jun 23, 2004 | 05:11 PM
B13F RS's Avatar
B13F RS
Stu at Motorsport Developments , Karl at Norris Motorsport , M A Developements , SCS in Peterboghorror.
There's a few about mate but unsure of the exact cost?? your better off phoning them and getting a price
Old Jun 23, 2004 | 06:38 PM
Matt's Avatar
Matt
send/tell him the spec as best you know it so he can set a base map to get the car running with them in, then it will be custom mapped to suit it once its there, i think thats how its done, mine was done that way like but karl knew EVERYTHING about my engine before hand. im 100% sure it can be sorted out however its done pal
cant remember if you had verniers on or the std pulleys? if std then get some verniers before you go to make the most of the non std cams you have, save arsing about and get it all done at once like
Old Jun 23, 2004 | 06:43 PM
GARETH T's Avatar
GARETH T
i wouldnt be to bothered about the rolling road if i was you unless you wanna talk numbers down the pub with your mate
as said loads of tidy people out there who car really help you
msd
norris motorsport
turbosystems
engine advtantages
MAD
all got a good rep and im sure they all cousl help you out
Old Jun 23, 2004 | 06:49 PM
B13F RS's Avatar
B13F RS
Nice one for that mate i've been looking into getting some verniers,i'm also changing my breather set up cause i aint happy about it,i've just got meself a Spec R catch tank that sits near the filter and i'm going to get the other breather that goes with it. The one i got at the mo is a universal one from spec R and is fookin rubbish
Old Jun 23, 2004 | 07:42 PM
SidZvh's Avatar
SidZvh
Now then bud. Didn't realise you'd got your injectors already. When you hoping for it to be done for?
Old Jun 23, 2004 | 08:31 PM
Beach's Avatar
Beach
hmmm, wonder who purchased them dingy??? should be ok for my erst me thinks cant see me needing anything better and karl will map it so it should be fine
Old Jun 23, 2004 | 08:43 PM
B13F RS's Avatar
B13F RS
Hey up sid welcome to the mad house....lol
Not in no rush mate
Old Jun 23, 2004 | 08:45 PM
BlackSaff's Avatar
BlackSaff
Swerv don't you mean my engine????
So does this mean i'm gonna see 400bhp then?
15k, you told me 10k
Old Jun 23, 2004 | 09:07 PM
Tim's Avatar
Tim
Greys now on order
Old Jun 23, 2004 | 09:12 PM
Chris, Blues are ok on a ERST mate They will be mint
Ave it Butcher...
Old Jun 23, 2004 | 09:32 PM
B13F RS's Avatar
B13F RS
Blues will be fine on mine too
Just want it to be ok at 25-26psi thats all and it won't on fookin 803's
Old Jun 23, 2004 | 09:35 PM
i ran mine @ 26 psi held on greens for 6 months with no issues and i did it my self
Old Jun 23, 2004 | 09:53 PM
Matt's Avatar
Matt
your "im happy with it as it is" bollocks lasted a long time then i see tim
nice one though, you know it makes sense rodders
Old Jun 23, 2004 | 10:04 PM
DaveEscos's Avatar
DaveEscos
greens are perfectly fine for 25 psi!
Old Jun 23, 2004 | 10:06 PM
Whats PSi got to do with this?
AIRFLOW is the key to destruction, not boost folks...
Old Jun 23, 2004 | 10:07 PM
Matt's Avatar
Matt
but 25psi isnt fine for a t34 car dave
Old Jun 23, 2004 | 10:08 PM
Rs Gus's Avatar
Rs Gus
who wants a puny 25psi
Old Jun 23, 2004 | 10:09 PM
DaveEscos's Avatar
DaveEscos
25 psi, on greens, on a t34 is fine then
Old Jun 23, 2004 | 10:12 PM
Rs Gus's Avatar
Rs Gus
NO is it fook theres too muck mass airflow for the greens 2 be abble to suply enough fuel then pop!
Old Jun 23, 2004 | 10:14 PM
DaveEscos's Avatar
DaveEscos
funny, my 28 peak, 25 held, wide open on nobles rollers on my esc cos a year or so ago was fine fuel wise.... same at EA with a little extra. Plenty of fuel
Old Jun 24, 2004 | 05:53 AM
B13F RS's Avatar
B13F RS
Dave i've ran 25psi on my current set up but was told to upgrade my injectors for the reason RSGus has said so shut it you muppet
southerners.......they know fookall!...lol
Old Jun 24, 2004 | 07:30 AM
Mike Rainbird
Caraholic
You can use multipliers in the EPROM and peak at 34psi and hold 26psi with 803s on a 0.48 a/r T3/4 NO PROBLEM . You get 385bhp / 403lb ft (engine dyno confirmed) and a 172mph car (Datron timing gear confirmed) .
Old Jun 24, 2004 | 07:41 AM
Disabled Account
Mike,
Thats impressive!
What was the comp ratio of that engine?
Standard head/cams???????
