Group N front diff.
Old Jun 22, 2004 | 07:31 PM
Dean Saff's Avatar
Dean Saff
Default Group N front diff.
Would you be able to tell the difference between one of these to a standard 4x4 front diff just by looking at it, Or are all the good bit's on the inside? Also what are the diference's between them?
Old Jun 22, 2004 | 08:11 PM
Porkie's Avatar
Porkie
Sorry mate, but isn't Group N showroom spec?? eg It is standard?
Best ask one of the Rallyboys but it may be someone trying to mug you off!
Old Jun 22, 2004 | 08:13 PM
NUTS RuS's Avatar
NUTS RuS
Group N is a bog standard scrapyard unit
Old Jun 22, 2004 | 08:30 PM
Dean Saff's Avatar
Dean Saff
Cheers mate, bit confused about what you wrote, what isn't group N?
I take it from that you mean that they look totally different
Old Jun 22, 2004 | 08:39 PM
Porkie's Avatar
Porkie
Group N is standard as far as I am aware...
The normal upgrades for a front Diff are the Quaife 'thick wall' casing and an ATB diff. Here are mine if it helps you....
Take some piccys of the items. Someone on here will help you
Old Jun 22, 2004 | 08:40 PM
RANJ's Avatar
RANJ
Group N is standard as far as I am aware... Nuts IS a Rally guy but there isn't alot more than can be said. The major and normal upgrades for a front Diff are the Quaife 'thick wall' casing and an ATB diff. Here are mine if it helps you....
yup same as mine
lets hope they last
Old Jun 22, 2004 | 08:42 PM
Porkie's Avatar
Porkie
I won't be doing any mad launches unlike you! fingers crossed for you...
any news on your gearbox matey?
Old Jun 22, 2004 | 08:44 PM
Disabled Account's Avatar
Disabled Account
Ranj, Porkie..............yup - same as mine too! Lets all hope that they last
Old Jun 22, 2004 | 08:47 PM
RANJ's Avatar
RANJ
feck all news porkster, fixit kits i dont think ill bother with as i spoke to the dude who builds them direct and he chats enuff crap, ill prob dyno engine and put back in on standard box , turn power down until i decide weathe rto use as pure track etc car and go for a propper box or see i take chances with apete doughty item, that way im driving the fukker
yes ill be launching the fuker alright
Old Jun 22, 2004 | 08:48 PM
Kevin Sharp's Avatar
Kevin Sharp
heres one of those i prepared earlier
Old Jun 22, 2004 | 08:49 PM
NUTS RuS's Avatar
NUTS RuS
Guy's they should last longer than a GP N one anyway
RANJ's Avatar
RANJ
ur just a fookin animal kev, u cant keep anything in one peice
Old Jun 22, 2004 | 08:50 PM
Porkie's Avatar
Porkie
To be fair to it, it did ALOT of hardwork before that though didn't it
RANJ's Avatar
RANJ
to fookin right it did
Old Jun 22, 2004 | 08:52 PM
Disabled Account
Dean, actually a good and cheap "half way" measure is to get the standard diff plated.
I once launched my old Saph, it went well up to about 50 MPH and then there was a loud knocking noise. The front diff casing had cracked in half!!!
Sent the unit to Steve Scott (A1 Rally Sport)....He then supplied me with another diff (standard internals) but a plated version - i.e. a specially made stainless steel plate that both halves of the casing bolts through (about 6 to 8 mm thick). This is a good low cost way to strengten the standard front diff.............About Ł 60.00 for the s/steel plate IIRC.
Old Jun 22, 2004 | 08:55 PM
Kevin Sharp
ok it did the odd launch now and again
Neil S's Avatar
Neil S
Originally Posted by Doug Stirling
Sent the unit to Steve Scott (A1 Rally Sport)....He then supplied me with another diff (standard internals) but a plated version - i.e. a specially made stainless steel plate that both halves of the casing bolts through (about 8 mm thick). This is a good low cost way to strengten the standard front diff.............About Ł 60.00 for the s/steel plate IIRC.
Sounds interesting
Can you describe in more detail? does it replcae the bottom plate or something?
Neil.
Old Jun 22, 2004 | 08:56 PM
dumped's Avatar
dumped
Yeah but porkie you are forgetting he did that in the car park - not on the 1/4 - typical ned behaviour ROFLOL
Kev - thought your car was off the road and being transfered into another shell - then i hear stories of some "small turbo" model running round knockhill the other day nossed up to the nines!
Martin
Old Jun 22, 2004 | 09:03 PM
Kevin Sharp
pmsl@ ned car prk behaviour
its getting transferred into another shell over the winter...when i have some spare time
yep it was me at KH but no nos onboard
Dean Saff's Avatar
Dean Saff
Yeah Doug sounds good any more info...
Old Jun 22, 2004 | 09:04 PM
Disabled Account
[quote=Neil S]
Originally Posted by plated version - i.e. a specially made stainless steel plate that both halves of the casing bolts through (about 8 mm thick). This is a good low cost way to strengten the standard front diff.[/quote
Sounds interesting
Neil.
OK..........You still keep the bottom plate/cover but you then ADD a stainless steel flange piece where the two join together, and then bolt the three pieces together very tight. It works because the original soft alloy casing would otherwise start to crack at the weakest point - the edge near the bolt holes. The s/steel plate prevents this from happening.
Old Jun 22, 2004 | 09:10 PM
Neil S's Avatar
Neil S
Cheers Doug Might consider that myself (even though mine is only a baby )- cheaper than a new diff
Are the threads in the casing not ally though?
Neil.
Old Jun 22, 2004 | 09:40 PM
Disabled Account
Neil.
Yes the threads are in the alloy casing, but it is the plate that does the work............
Have a look at these pics of my broken standard diff casing:
Old Jun 22, 2004 | 09:43 PM
Dean Saff's Avatar
Dean Saff
Old Jun 22, 2004 | 10:16 PM
Azrael's Avatar
Azrael
There actually are different FINIS numbers for Group N item in Rally prep manual, but it's probably only cark tested and selected form production line.
Old Jun 23, 2004 | 07:06 AM
Neil S's Avatar
Neil S
Cheers Doug - Cleared that up for me
Will probably end up getting one
Neil.
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
cossirob
Sep 3, 2015 09:17 PM
