cossie fuel pressure question?
Old Jul 9, 2005 | 08:37 PM
kossykarl's Avatar
kossykarl
Default cossie fuel pressure question?
hi chaps just a couple of questions for the knowledgeable ones amongst you - thanks
car is 4x4 saffy cosworth green top stage 1
1 whats the best way to test the fuel pressure ( before or after the regulator)
2 i know it should be 4 bar at idle but should this increase with revs or should it be constant
has anyone fitted a fuel pressure gauge inside their car if so how did you connect it to the fuel line.
i`m sorry if these questions seem dumb but i would rather look stupid and ask than risk buggering something up.
cheeRS karl
Old Jul 10, 2005 | 09:20 AM
alan rainbow's Avatar
alan rainbow
fit gauge between regulator and fuel rail 4 bar at idle is high who as advised this
Old Jul 11, 2005 | 07:16 AM
kossykarl's Avatar
kossykarl
sorry my mistake , graham goode web site states 3 bar at idle.
cheers karl
Old Jul 12, 2005 | 02:26 PM
cossie604's Avatar
cossie604
lol agreed, 4bar is a tad high (lol had to use that smiley cos its great) Off top of my head I think fuel pressure should be between 2.8 and 3.3bar
Old Jul 12, 2005 | 02:44 PM
2001ode's Avatar
2001ode
Hi,
Basic fuel pressure is 3.5 bar. (running engine and hose disconnected from regulator or fuel pump running alone)
If you are on idle, inlet pressure is - 0.8 bar (common value) and your fuel pressure should be 3.5 - 0.8 = 2.7 bar
If you are on charge, ie with stage 1 EPROM with 1.1 bar TC pressure, your fuel pressure should be 3.5 + 1.1 = 4.6 bar.
Regards.
Claude
Old Jul 12, 2005 | 08:53 PM
july1's Avatar
july1
I've fitted a fuel gauge on my escort to achieve it have replaced the plastic lines by braided lines and by the way screwed a T piece to fit the gauge (expansive but definitely the right way to do it.
Another possibility is to weld a bung on the rail to fit the transmitter or the gauge
If you wanna fit the gauge inside you need to supply an electric one (with a transmitter so no fuel inside the car) mechanical ones are cheaper but shouldn't be fitted inside.
Old Jul 13, 2005 | 11:17 PM
cossie604's Avatar
cossie604
Originally Posted by 2001ode
Hi,
Regards.
Claude
So roughly then, do you raise the fuel pressure say 1bar for every 1 bar of boost increase from standard?? At what sort of pressure would injector lock kick in at?? Is a cosworth fuel regulator progressive with boost increase?? Sorry for many questions but I like to learn
Old Jul 14, 2005 | 08:12 AM
2001ode's Avatar
2001ode
As I say, fuel pressure is in direct relation with inlet manifold pressure, and constantly change, as manifold pressure.
Sorry for this pic of fuel regulator, in french.
Regard
Old Jul 15, 2005 | 10:58 AM
kossykarl's Avatar
kossykarl
checked fuel pressure with gauge - only got 2 1/2 bar at idle and 3 bar with vac pipe removed- fitted new regulator but still the same could it be a weak fuel pump that is causing the drop in fuel pressure and causing car to run lean ??
cheers karl
Old Jul 15, 2005 | 11:25 AM
2001ode's Avatar
2001ode
Hi,
2 possibility :
default on fuel pump
default on your gauge
What is your choice ?
Regards
Claude
Old Jul 15, 2005 | 11:50 AM
kossykarl's Avatar
kossykarl
hi there 2001ode!
no problem with gauge mate as both the pressure gauge and my afr meter are ok, deffo running lean as its running hot and lacking power i have already replaced filter and regulator so the problem has got to be with the pump surely????
cheers karl
Old Jul 15, 2005 | 04:27 PM
alan rainbow
karl ive got a pump you can try if you want
Old Jul 15, 2005 | 05:41 PM
july1's Avatar
july1
This will be the best thing to do!
Old Jul 15, 2005 | 06:22 PM
kossykarl's Avatar
kossykarl
thanks !!!!! Alan ,but i`ve bit the bullet and ordered one from GK Ford they will deliver it to work tommorow ( I am parts supervisor for an iveco , ford and seddon atkinson main dealer so get most of my bits at cost) i will let you know how i get on with it but thanks for the offer it was good of you.
by the way where abouts in notts are you iv`e seen your posts on this board all the time and just wondered.
cheeRS Karl.
Old Jul 15, 2005 | 06:42 PM
alan rainbow
cheeRS Karl.
no probs mate iam in aspley notts
Old Jul 17, 2005 | 07:33 AM
july1's Avatar
july1
Another key point to check would be the voltage @ the pump. The poor fuse box is a common problem on escort but as your sierra is getting old such trouble may happen too.
The voltage drop should not be more than 1v.
mickparky81
Ford Focus ST
Aug 30, 2015 06:58 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
