ok explain this then ?????????
Old Jul 9, 2005 | 06:53 PM
Combi_Chris's Avatar
Combi_Chris
Default ok explain this then ?????????
escort turbo with cossie management .
the car starts up and ticks over at 3k with the cold start plugged in, if unplugged ticks over at 1k .splutters on boost.
as soon as the car is warm it dies, and wont start unless i disconnect 2 injectors , i have no idea why other than a remap, as im running on a base map, any ideas anyone ????
Old Jul 9, 2005 | 06:55 PM
Ryan's Avatar
Ryan
wrong Fuel Pressure?
Old Jul 9, 2005 | 06:57 PM
DazC's Avatar
DazC
Cold start?
Old Jul 9, 2005 | 06:58 PM
Combi_Chris
even when warm with the cold start unplugged it STILL dies , im about to garage the car now as i cant use it , i just spent my last money getting it fixed , and now it wont even run
Old Jul 9, 2005 | 07:07 PM
Combi_Chris
ok whats the best place to take my car , that can diagnose the problems , get the parts fix them on to the car , map it , and GUARANTEE the work in the essex area ? ?
Old Jul 9, 2005 | 07:13 PM
Graceland's Avatar
Graceland
Team HOTHOT!
coolant temp sensor
also check the 2 outer wires on the tps arn't back to front
Old Jul 10, 2005 | 12:30 AM
Combi_Chris
coolant temp sensor has had a new plug fit only tuesday just gone , wont be that , the wires also are ok
Old Jul 10, 2005 | 12:41 AM
NUTS RuS's Avatar
NUTS RuS
Poss fuel problem to me to
No idea where could sort it out local to you tho' sorry.
I travelled about 300 miles to get mine mapped
Old Jul 10, 2005 | 10:52 AM
DazC's Avatar
DazC
Cossie management doesn't have a cold start valve. So what do you mean by cold start?
Old Jul 10, 2005 | 11:55 AM
Ginge !'s Avatar
Ginge !
just finding my feet
jano aint far from ya mate
Old Jul 10, 2005 | 12:17 PM
CozzyBrom's Avatar
CozzyBrom
injector phasing sounds like
what you using for a dizzy
we have has this before on dizzy that been put together wrong and the phase sensor 180 out
Old Jul 10, 2005 | 06:44 PM
jon@work's Avatar
jon@work
Sounds very similar to a problem I sorted out last weekend - car wouldn't start unless the wiring to all 4 injectors was unplugged - it was the wiring to the water temp sensor that was at fault. To check yours is OK, take the back off the ECU multiplug, replug it onto the ECU, and switch the ignition to position 2 (engine off). Measure the resistance between pins 11 and 29 - should be up 800 to 5000 ohms. If higher, change sensor, or investigate wiring - has a pin pushed out of the new plug, or is there a dodgy joint?. (info above courtesy of Simon@SECS).
JK12
33
Apr 26, 2021 12:09 PM
hopper350
Sep 4, 2015 12:53 AM
Sheepdisease
Aug 30, 2015 09:11 PM
Caddyshack
Aug 19, 2015 07:29 PM
