ERST dieing after start up
Old Jul 7, 2005 | 04:33 AM
CraigW's Avatar
CraigW
Default ERST dieing after start up
Hiya, what it is the car starts up fine first time, then after about a minute slowly dies and dies and then boomf "dead", any ideas why its lasting a minute then slowly dieing and dies ?
Old Jul 7, 2005 | 09:34 AM
davidnormanuk's Avatar
davidnormanuk
Does it do it when the car is cold?
Dave
Old Jul 7, 2005 | 02:44 PM
CraigW's Avatar
CraigW
Dave
i start it up mint and run's fine for about 30seconds and it just slowly dies, doesnt last over a minute, the rev's get lower and lower and die
Old Jul 7, 2005 | 03:35 PM
davidnormanuk
Sounds like fuel starvation.
Dave
Old Jul 7, 2005 | 03:43 PM
CraigW's Avatar
CraigW
Dave
fuel pump works, cause i can hear the sound it makes when you turn the key, would it be my fuel filter getting blokes up on the right hand side ?
Old Jul 7, 2005 | 04:00 PM
davidnormanuk
Best way to check is to undo one of the injector pipes on top of the fuel distributor and see if fuel comes out of there when you turn the car over. I know the injectors open up when a certain pressure is hit. If that pressure isn't there the injectors will stay closed.
If there's hardly any fuel there. Try pressing the paddle down slightly when turning the car over to see if its any better. Could be down to a blocked airfilter etc.
Dave
Old Jul 7, 2005 | 04:29 PM
CraigW's Avatar
CraigW
Dave
I'll try that, also another thing, 2 nights ago i pulled off at the traffic light and put my foot down a little, then came onto the motorway and realised there was no whistle, boost or dump valve, i havnt a clue cause i look after the car, always let it warm up and cool down, never thrash it at all.
Any idea's why my turbo isnt working ?
Old Jul 8, 2005 | 01:40 PM
davidnormanuk
Sounds like maybe one of your boost pipes are split. If not then it could be your turbo/actuator/amal valve.
Dave
Old Jul 8, 2005 | 03:34 PM
IANS2RST's Avatar
IANS2RST
air leak, only reason the car runs initially is because the cold start valve is adding the extra fuel which will compensate for a small air leak.
Old Jul 10, 2005 | 07:57 PM
CraigW's Avatar
CraigW
yep an air leak was the problem, i forgot to put one of the screw's back on the turbo when i took all the hoses and turbo off, car is running fine now, just need a new turbo and im back on track.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
kevin36
Sep 2, 2015 06:24 PM
