FUKK IT
Old Jun 22, 2004 | 01:02 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Default FUKK IT
just phoned powerstaion in cheltenham, regarding my unichip and throttle bodies.
they say a unichip cant be used with TB's.
anyone got any very cheap aftermarket magagement going
Old Jun 22, 2004 | 01:03 PM
Ryan's Avatar
Ryan
are you TB's injected or carbed?
Old Jun 22, 2004 | 01:14 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
injected
basically, im keeping the zetec injectors, and where the TB injecters were, they are gonna be used for the idle control and brake servo vaccum
Old Jun 22, 2004 | 01:17 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
its because of the MAF sensor, it would not be used and they say it cant work out throttle angle X revs.
it only modifies the original signals or summut
Old Jun 22, 2004 | 01:25 PM
Jim Galbally's Avatar
Jim Galbally
you could use an airbox for the TBs and have the feed to the airbox going via the maf sensor?
that'd restrict the f**k out of the airflow tho
Old Jun 22, 2004 | 01:29 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
yeah, thought about that too, but 1 other problem, lack of space.
i could use the airbox that came with the TB's, but id have to lop a hole in the bonnet.....
Old Jun 22, 2004 | 01:31 PM
Ryan's Avatar
Ryan
cossie manangement
Fiesta OFAC/OFAB
DTA
Old Jun 22, 2004 | 01:36 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
ryan, how much do they cost, can i use my existing sensors, will i need other sensors????
and also, how would i fit them??
completely do away with the zetec ecu all together?
Old Jun 22, 2004 | 02:26 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Old Jun 22, 2004 | 02:27 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Old Jun 22, 2004 | 05:39 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Speak with Simon @ SECS, seriously, top top management, and he will do you a deal im sure.
You are in Bradford, he is in Westbury, take 5mins to meet up and have a chat Say Phil sent you
Old Jun 22, 2004 | 05:47 PM
Ragtop's Avatar
Ragtop
Surely Cossie and FRST ECU's would fall foul of the same problem, as they both require MAS/MAP sensors... ?!?! You'd have to use a NA only setup I presume..??
Isn't it a 2D one you need.. Just speed and TPS.. where-as the Zetec one you've got is probably a 3D one with Speed, TPS and Load... and with TB's (without an airbox) you can't measure the load as a whole... ?!?!?! Not that I profess to know that much, i'm only guessing..
Luv
Chrisie...
Old Jun 22, 2004 | 10:16 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
phil, i did pm him.
he said to get new management, didnt say his tho.
chrisie, fook knows!
Old Jun 22, 2004 | 11:11 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
will cosworth L6 ecu work??
a few cheap on ebay at the mo
Old Jun 22, 2004 | 11:46 PM
richm's Avatar
richm
Best method IMO for TB's is to map fuel and spark angle with Throttle Angle vs. RPM.
You will need aftermarket management for this though, most (if not all) OEM systems will use MAP or MAF sensor based load sensing.
Old Jun 23, 2004 | 07:26 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
bugger
well the booklet on the unichip says it can be used with throttle bodies!!
bastards
Old Jun 23, 2004 | 08:14 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
maybe (no idea but you say it says so) unichip can be made to run TBs by someone good, someone with skills, a decent mapper/tuner.
but you went to powerstation
Old Jun 23, 2004 | 08:44 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
no, it was fitted by the guy that i got the car off, somewhere in boulton.
but i rang powerstation for advice, cos they fit them.
Old Jun 23, 2004 | 09:02 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
maybe get a second opinion of somebody good then if Unichip think they can run TBs
Old Jun 23, 2004 | 09:25 AM
CraigN's Avatar
CraigN
lol unichip
everyone said they are a bag of wank dood
webber do a ecu for this ask the guy with the orange mk2 fiesta from www.zetecinside.com
he runs a focus 2ltr lump on injected tbs
Old Jun 23, 2004 | 12:34 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
well, ive just spoke to a guy from millway sport in andover, he said it may work
he says that he would take a set value from the maf and work either side of it, or something.
he said it may work, it may not.
but its 2 days work and gonna cost me £600 just to find out....
anyone got a DTA or OMEX or anything lying around cheap
Old Jun 23, 2004 | 12:36 PM
richm's Avatar
richm
or Emerald M3D - that one was originally designed for TB format, throttle angle vs. RPM
Old Jun 23, 2004 | 12:41 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
how much do they go for rich???
its looking like im gonna have to bin the t/b's now as i cant afford the new management
Old Jun 23, 2004 | 12:44 PM
B19-TRB's Avatar
B19-TRB
Have u thought to put a call in 2 uncy stu!? sure he could do somethin for ya!
Old Jun 23, 2004 | 12:48 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
lewis, will he be able to make it work then??
i know the guy is quite handy at tuning etc, but with everyone else saying its nigh on impossible i dont know what to do.
ill pm him
Old Jun 23, 2004 | 01:25 PM
richm's Avatar
richm
http://www.emeraldm3d.com/
Old Jun 23, 2004 | 01:30 PM
richm's Avatar
richm
ill pm him
I'd be very surpised if a MAP/MAF based system would be able to use a throttle position as primary load measurement, as the algorithms will be quite different..
..waiting to be shot down by Stu...
Old Jun 23, 2004 | 02:16 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
no need to worry rich, he cant do it.
tb's are in the bin!
Old Jun 23, 2004 | 03:17 PM
richm's Avatar
richm
hey,,, whoa... hope that is only a figure of speech...
Old Jun 23, 2004 | 09:02 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
yeah, ok, they are still in the garage
BUT
i thought bollox to it
i unplugged the maf sensor!
and drove 10 miles
after 2k revs, it was fine, went like a c*nt infact
but under 2k it was a bit hesitant.
so.
if i stick a resistor accross the maf wires and leave it unplugged, it might just work...
a bodge yes, but if it works, itll do!
Old Jun 24, 2004 | 08:40 PM
Ragtop's Avatar
Ragtop
You're forgetting that a Uni-Chip is a "Piggy-Back" chip... NOT an ECU, perce...
All it does is intercept the signals from the sensors and modify them before sending them on to the ECU.. It simply fools the Ford management... !!!!
So, this still doesn't help with TB's, as the Zetec management most likely won't work... wot with it requiring a MAS/MAF signal...
See if you can sell it to someone who's 'zetecing' and old fezzy or scort, and buy a dedicated system...
Luv
Chrisie...
Old Jun 24, 2004 | 08:54 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
how much do you rekon i will get for it if i sell the unichip and ford ecu together??
£200?
Old Jun 24, 2004 | 09:31 PM
Ragtop's Avatar
Ragtop
Well you can sell the uni-chip to anyone..!! I was looking at one for mine... Are they the same unit for all Ford EEC ECU's..?? Cuz that would broaden it saleabilty to peeps like me... (not that I can afford it.. )
The ECU will be harder to shift, i would think, as it's only gonna appeal to a modder (2L zetec in a Mk1 fezzy kinda thing), or someone who's ECU has died...
Luv
Chrisie...
Old Jun 25, 2004 | 05:47 PM
Mark V8's Avatar
Mark V8
I ran Emerald with my GSXR bodies on my old RS2000 and it just made 216bhp on Power engineerings rollers, so it can't be bad
If you have plenty of time and patience.
http://bgsoflex.com/megasquirt.html
http://www.bgsoflex.com/mjl/mjl_edis.html
Mark
Old Jun 25, 2004 | 05:52 PM
Roy's Avatar
Roy
£200?
there was a unichip on ebay a while back and i think that went for around the 200quid mark
Old Jun 25, 2004 | 06:23 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
roy, wanna buy one
mark, is that a build it yourself ECU then, and, will it actually work??
Old Jun 25, 2004 | 06:30 PM
Mark V8's Avatar
Mark V8
roy, wanna buy one
I know two people running it with no problems. You have to bear in mind the Megasquirt is fuel injection only so you would need to retain your original ecu to trigger the coils or build the Megajolt to go with the Megasuirt.
Mark
Old Jun 25, 2004 | 06:31 PM
Roy's Avatar
Roy
roy, wanna buy one
nope but i am sure you could sell it easy on the escort site or ebay
Old Jun 26, 2004 | 10:00 PM
Mark V8's Avatar
Mark V8
Megasquirt forums
http://www.msefi.com/index.php?c=2
Mark
EDIT for another link
http://www.megasquirt.info/UMS.htm
pee vee
Ford Focus RS
Mar 28, 2011 03:12 PM
scoobypete
13
Sep 4, 2009 07:41 PM
Fudgey
11
Jan 23, 2005 09:10 AM
Fudgey
Jul 21, 2004 10:11 PM
Fudgey
14
Jul 16, 2004 08:31 AM
