Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
mk 1 fiesta losing power
Old Jul 5, 2005 | 05:51 PM
pifular's Avatar
pifular
Default mk 1 fiesta losing power
i have decided to relive my youth and i bought a mk1 fiesta recently (81 1.1L) and have got it through its mot etc with lots of work however all the time i haved owned the car its has suffered from almost total power loss when the engine is warm and under load. when this happens full throtle is needed and the car just about ticks over on the verge of stalling. i have changed the plugs, leads, cap, rotor arm, condensor, coil and points which i have gapped. the problem is still there. the jet at the top of the carb ( ford not webber) seems to jet fuel fine when looked at with the air box off, does any one have suggestions as i do not want to give up on the car for the sake of this. the bodywork is sound and it has only done 41500 miles. if it makes a diffence the inside of the carb is black and the new air filter (ring style) i fitted recently has lots of fresh oil on the inside of it.
Old Aug 20, 2005 | 01:17 AM
rodney's Avatar
rodney
try gettin the timin checked , and check there is no vacume leaks from around the carb or inlet , and clean the jets in the carb out with carb cleaner,.
DHMC
Ford Fiesta
Sep 30, 2015 07:15 PM
liamT74
Sep 23, 2015 10:24 PM
Dubs44
Sep 19, 2015 06:31 AM
Flatlinedan
Sep 18, 2015 12:41 PM
Maxwell
Fiesta ST
Sep 13, 2015 05:31 PM
