2WD FAN SWITCHING ??? quickie
Old Jul 4, 2005 | 06:03 PM
rabmc's Avatar
rabmc
Default 2WD FAN SWITCHING ??? quickie
Gonna fit a switch to control my fan on my safcos so am i right in saying i switch a positive through a switch ?? and take to positive of fan ? is it a hard/constant negative the fans have anyways , hope u get what im saying lol and wheres best place to fit on a saff dont wanna ruin anything on dash by putting holes in etc ? where do ppl put em on these cars probably going to disconnect rear fog wires and put it throgh that switch alredy on dash that wa with light so i know its on and just need to re-conncet mot time
Old Jul 4, 2005 | 09:12 PM
velocity's Avatar
velocity
you could do it this way and its much easier,go to the fan switch on the side of the rad,on the connector there will be either one or two brown wires (earth) and another colour wire(not sure of the colour) which be should be a permanant live.simply splice into the permanant live wire and run the spliced in wire to a switch on your dash then earth the other side of the switch,
all you are doing is manually earthing the rad switch,you should have one fan opperate with ignition off and both fans with ignition on,although this may not always be the case
Old Jul 5, 2005 | 03:49 PM
rabmc's Avatar
rabmc
No bother works the same but probably a bit easier that way true , thanks
Old Jul 6, 2005 | 04:27 PM
rabmc's Avatar
rabmc
so am i right in saying the fan operates by a switching positive and has constant earth/negative
Old Jul 7, 2005 | 07:10 PM
velocity's Avatar
velocity
the fan relays are drive the fans are switched buy the rad fan temp switch,the rad temp switch gets a constant live and only earths when the rad temp reaches a certin level,
one of the fan relays switching supply is a constant live and the other only when the ignition is on,thats why only one drives with the ignition off,
hope that is some help
Old Jul 22, 2005 | 07:25 AM
Eagle's Avatar
Eagle
Super Moderator
the best way is to use the rad fan switch to drive relays to power each fan,
i know its a bit of extra cost but if you want the fans on constantly it has been known for the fuse holder to melt in the fuse box.
the rad temp switch is negative switched btw
Old Jul 22, 2005 | 01:23 PM
rabmc's Avatar
rabmc
Right lads my car already has a relay down there near fans behind passenger headlight area
It has 2 red wires coming in 1 from batt and one goes into my car/dashboard then on the other side of the relay theres a black which goes to earth and another red which goes down to fan connector is this what yous are talking about lads and what do yous think the red wire going into dash does need to trace it actually
Old Aug 14, 2005 | 11:45 AM
rabmc's Avatar
rabmc
BTTT
Old Aug 14, 2005 | 03:58 PM
boost mad's Avatar
boost mad
https://passionford.com/forum/viewtopic.php?t=121444
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
rsguy
44
Sep 29, 2015 03:29 PM
cossie330
Sep 27, 2015 04:13 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
