Can you fit a grpA coil to a non-cossie?
Old Jun 22, 2004 | 08:05 AM
Jim Galbally's Avatar
Jim Galbally
Default Can you fit a grpA coil to a non-cossie?
i presume you can as at the end of the day its only an ignition coil... right?
just thinking ahead if mine turns out to be fugged... if the grpA is only 40quid i would probably be better off getting one of those rather than a std one for 30quid..
Old Jun 22, 2004 | 09:12 AM
Stu @ M Developments's Avatar
PassionFords Creator
You can fit a better coil to anything.
Old Jun 22, 2004 | 09:13 AM
Jim Galbally
danke schon
Old Jun 22, 2004 | 09:17 AM
zvhturbo's Avatar
zvhturbo
Stu what if the Dwel times of the coils are different??
Will it damage the coil or other components?
Ginge !'s Avatar
Ginge !
just finding my feet
even keiths car has one
borboyous
Aug 22, 2015 11:17 AM
marky_g
Aug 15, 2015 10:43 AM
155lee
Aug 14, 2015 11:21 AM
Zoggon
Aug 10, 2015 10:39 AM
ricky
Jul 31, 2015 10:30 PM
