brake/fuel pipe's inside car can you help!!!
can any one help me =am renewing the brake and fuel pipe's on my cossie saff and i want to put the pipe's inside the car and not under it can i do this and if so how!!!!!!!!!!!
cheers frank
cheers frank
Brake pipes are easy.
Obviously you have removed the carpets etc?
Then from the ABS block remove the two pipes that feed the rear brakes, drill a hole in the bulkhead, fit a srecial 'bulkhead fitting' and pipe onto it and through the car the other side. When you come to going back out of the car use the same type of fittings.
Should be available from any decent rally car shop or Rally Designs.
They should be able to help you with the fuel lines too using a similar method I assume.
track.focus'd
Aug 12, 2015 05:53 PM
marvin
Fiesta RS1800/RS Turbo
Aug 10, 2015 11:14 PM
Red_bull
Aug 9, 2015 08:34 AM
