idle problem
Old Jun 29, 2005 | 02:20 PM
nick_GTI's Avatar
nick_GTI
Default idle problem
I've got a escort gti 1.8 zetec and is having trouble idling. When i start the car the rev counter goes from below a 1000 to 3000 and below a 1000 up tp 3000 and sumtimes the car will cut out untill the car is warm and its not to bad. Any idea's? cheers
Old Jun 29, 2005 | 10:18 PM
saigonij's Avatar
saigonij
try cleaning out the ISVC with carb cleaner, and then take the throttle body off and do the same.
Old Jul 7, 2005 | 07:39 AM
nick_GTI's Avatar
nick_GTI
I no this might sound a silly question but wot is the ISVC?
Old Jul 7, 2005 | 05:56 PM
sammy's Avatar
sammy
idle speed control valve, its located under the inlet manifold, held on with 2 x 8mm(headed) bolts, if that dont work, check the valve on top of the breather is ok & assosiated hoses (under exhaust manifold), usually iscv though
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
