cold start
Old Jun 28, 2005 | 06:16 PM
efiturbocab's Avatar
efiturbocab
Default cold start
cant get my s2 to start and keep running. she will start and run fine for a min or two then just stop but if i take it for a run till it worm she will run fine changed the cold start valve still no change do u think i should go get it set up [more money]
Old Jun 28, 2005 | 06:31 PM
S1MAN's Avatar
S1MAN
Sounds like you may have an air leak somewhere.
I had the same prob with the S1 years ago, turned out to be that the nuts that hold the throttle body in place needed nipping up. Once it was warm and the aluminium had expanded it ran fine.
Colin.
Old Jun 28, 2005 | 06:37 PM
efiturbocab
had it all to bits with a new inlet so i dont no think its got to go in for a set up
Old Jun 28, 2005 | 08:26 PM
davidreader5's Avatar
davidreader5
HI,
Is the thermo time switch , which operates the cold start valve working(power to valve) other wise check for air leaks, co%, and timing is correct.
DAVE R.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
gingeRS
Sep 4, 2015 06:29 PM
