link to some pics of my car and new bits and pieces! UPDATED
Old Jun 27, 2005 | 10:59 PM
rapidcossie's Avatar
rapidcossie
Default link to some pics of my car and new bits and pieces! UPDATED
https://passionford.com/forum/viewtopic.php?t=118232
enjoy!
Old Jun 28, 2005 | 02:09 AM
TurboFlush's Avatar
TurboFlush
what is this wire ringed you talk about? and the long studing (never been answered yet), is that jjust drilling the stud holed deeper to take longer head studs?
nice pistons. I need to start looking at my options. . . what comp. ratio are those going to be?
TF
Old Jun 28, 2005 | 11:16 AM
rapidcossie
long studing is basically what you said.
the block is wire rung by machining a small ring into the surface of the block which is filled with some kind of ring/wire, as the head is tightned onto the block this forms another seal to help the head gasket deal with the stresses.
pistons are 7:1 JE
Old Jun 28, 2005 | 07:13 PM
TurboFlush's Avatar
TurboFlush
pistons are 7:1 JE
Ohh I knew what Wire Rung was. My brain has to be rebooted sometimes.
You must have plans of some scary power by the sounds of what I am reading so far. good stuff.
I wish I would of known of Long Studing before I bought the ARP studs I have. :-(
TF
Old Jun 28, 2005 | 10:21 PM
rapidcossie
think the pitch of the thread on the studs is finer as well?
power i am aiming for will be "enough"
Old Jun 29, 2005 | 01:06 AM
TurboFlush's Avatar
TurboFlush
but how much is enough. . .
I am used to 100hp so 300hp should be enough for me for awhile. But I am also using a OHC head instead of the cosworth in my build. so 300 is a good place to be. I will be running around 8:1 comp though. gota keep it drivable when the turbo is not active (auto-x racer)
Old Aug 28, 2005 | 01:00 PM
rapidcossie
was down at AVA yesterday
fully assembled bottom end, everything new apart from the crank.
about to be fitted to a fully overhauled group A ported and polished head running high lift cams
hybrid t4 came from and escort cossie race car that made 437 at the wheels at AVA si at least i know its up to the job!
new wheels, cheers Andy!
new engine mounts
Old Aug 28, 2005 | 05:03 PM
NUTTIN RILLA's Avatar
NUTTIN RILLA
Euan how much were your mounts, and where did you get them from mate, oh and the cars coming on well
Old Aug 28, 2005 | 10:08 PM
rapidcossie
got the mounts from racespec motorsport but think woodford do them to.
not sure how much they are tho
JoeyBoyden
Jan 4, 2024 02:36 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
vdubo7
Aug 2, 2015 08:17 PM
