T3 turbo differences
Old Jun 27, 2005 | 11:13 AM
spence.perry's Avatar
spence.perry
Default T3 turbo differences
I recently had to replace my turbo on my 2wd saf. I had a T3 with a reworked compressor housing to 4x4 spec on it. I replaced it with one of the same spec but the car has lost its punch. I had the car on the rollers and I found the I have lost 30BHP. I think I have been sold a standard T3. Can anyone tell me what the difference is in the size of compressor housing between a 2wd T3 and the larger T3 from a 4x4
Old Jun 28, 2005 | 09:39 AM
2001ode's Avatar
2001ode
Hi,
I believe that comp. housing are same. (0,42)
Comp. wheel is different, trim .55 for 4x2, trim .60 for 4x4.
Is it right ?
Regards.
Claude
Old Jun 28, 2005 | 11:03 AM
spence.perry
Thanks Claude
I have measured it and I do have a 2wd T3. I have been told the 4x4 flows 10% more air so that would make sense as I am only getting 300bhp on the same rolling road I always use running the same boost. Oh well that was a waste of money I will have to sell it and make sure I get one with the 4x4 compressor wheel in it.
Spence
Old Jun 28, 2005 | 11:23 AM
wimwerf's Avatar
wimwerf
compressor housings are different also...the inlet of the houses are different....if you see inside the inlet you see the 2wd is different instead of the 4wd...
a 2wd compressor hous has an edge inside and the 4wd doesnt....
Old Jun 28, 2005 | 12:31 PM
spence.perry
Yep I got a big step about half way down the inlet to my turbo yet again confirming a 2wd turbo.
Thanks
Spence
Old Jun 28, 2005 | 02:41 PM
Franco's Avatar
Franco
Hello trouble!!!
Its Jason!
I told you in the first place not to bother with that T3! Get a manly T34
Matt Baxter
Sep 16, 2015 08:30 PM
muz
Aug 16, 2015 12:57 PM
A.t.p
Aug 15, 2015 11:37 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
Hellraiser
Aug 8, 2015 04:19 PM
